Ethernet standard
How long does 10BaseFX & 100BaseFX can transmits data?
2 Accepted Solutions
Leo Laohoo
I do not believe 10BaseFX actually exist.
100BaseFX will depend entirely on what optics is used.  The complete list, including distance, can be found in the Data Sheet.
on a side note, according to the below extract from Wikipedia,10BaseFX actually DOES seemto exist. I had never heard of it either...
"10BASE-F, or sometimes 10BASE-FX, is a generic term for the family of 10 Mbit/s Ethernet standards using fiber optic cable. In 10BASE-F, the 10 represents a maximum throughput of 10 Mbit/s, BASE indicates its use of baseband transmission, and F indicates that it relies on medium of fiber-optic cable. The technical standard requires two strands of 62.5/125 µm multimode fiber. One strand is used for data transmission while the other is used for reception, making 10BASE-F a full-duplex technology. There a three different variants of 10BASE-F: 10BASE-FL, 10BASE-FB and 10BASE-FP. Of these only 10BASE-FL experienced widespread use.[1] With the introduction later standards 10 Mbit/s technology has been largely replaced by faster Fast Ethernet, Gigabit Ethernet and 100 Gigabit Ethernet standards."
Leo Laohoo
Thanks sir,i understood
