cisco 1941 how to configure the multiple portforwarding
Hi guys,
below mentioned the portforwading working on single port portforwading but we need to multiple portforwarding how to configure.
ip nat inside source list 100 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.1.22 491 interface GigabitEthernet0/0 491
ip nat inside source static tcp 192.168.1.9 3389 interface GigabitEthernet0/0 3389
ip route 0.0.0.0 0.0.0.0 xx.xx.xx.xx
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 100 permit tcp host 192.168.1.22 any
access-list 100 permit udp host 192.168.1.22 any
we need to open the below ports,
1720 (TCP), 14085-15084 (TCP) and 1719(UDP), 16386-25386 (UDP).
please help on this.
Mark Malone
Hi you could port forward doing ranges like below link , you do it through the acl
https://community.spiceworks.com/how_to/108577-how-to-nat-in-a-cisco-router-for-a-large-range-of-ports
i am try but not working.
a.alekseev
Level 7
Level 7
I think, that you need open 1720 (TCP) and 1719(UDP). As for the rest, NAT will do it for you.
