2821 Router Query
yun zhang
Hi All
We have a cisco 2821 router , for now we need five layer three ports for WAN connection , can I install HWIC-1FE + HWIC-2FE  simultaneously on the router ?
harvey
2 Accepted Solutions
Chhabi Thapa
Hi Yun Zhang,
Yes you can use both HWIC-1FE and HWIC-2FE simultaneously on your router.
Joseph W. Doherty
Unless Chhabi has seen such actually work, from table 1 in: http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/product_data_sheet0900aecd80581fe6.html perhaps not.  There might be a limitation of just two more routed ports.
Chhabi Thapa
Hi Yun Zhang,
Joseph W. Doherty
Thanks for sharing the link Joseph and sorry for my sheer ignorance.Actually one of my client is using 4 HWIC-2FE and 2 HWIC-1FE card on their 3845 router.
