Flexible Netflow not working - 4331 Router
ittechk4u1
Level 4
Level 4
Hello experts,
I am using these commands:
flow record NTArecord
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 collect ipv4 tos
 collect transport tcp source-port
 collect transport tcp destination-port
 collect transport tcp flags
 collect interface input
 collect interface output
 collect counter bytes
 collect counter packets
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
exit
flow exporter NTAexport
source vlan 6
destination 192.168.2.18
transport udp 9995
export-protocol netflow-v5
template data timeout 60
exit
flow monitor NTAmonitor
exporter NTAexport
record NTArecord
cache timeout inact 15
cache timeout act 60
exit
interface vlan 6
ip flow monitor NTAmonitor input
Int gig0/0/0
Could you please check and find out the root cause why net-flow is  not working
Thanks in Advance
have you tried set the output too under vlan 6 interface too
can you ping the collector ok  192.168.2.18 ?
this is a base working one of one of my switches generally the same as whet you have , what  ios-xe version are you running on the router
ip flow monitor MonitorA input
ip flow monitor MonitorA output
flow record FLOW-RECORD
 description record to monitor network traffic
 match ipv4 tos
 match ipv4 protocol
 match interface input
 match interface output
 collect routing source as
 collect routing destination as
 collect routing next-hop address ipv4
flow exporter NetQos
 description export Netflow traffic
 destination x.x.x.x
 source xxxxx
 template data timeout 300
 option interface-table timeout 1000
 option exporter-stats timeout 1000
 description Used for ipv4 traffic analysis (Mapped To FLOW-RECORD)
 record FLOW-RECORD
 exporter NetQos
 statistics packet protocol
#sh flow exporter statistics
Flow Exporter NetQos:
  Packet send statistics (last cleared 1y4w ago):
    Successfully sent:         84545041              (105302149547 bytes)
    No destination address:    24                    (30196 bytes)
  Client send statistics:
    Client: Option options interface-table
      Records added:           11924274
        - sent:                11924002
        - failed to send:      272
      Bytes added:             1192427400
        - sent:                1192400200
        - failed to send:      27200
    Client: Option options exporter-statistics
      Records added:           34172
        - sent:                34171
        - failed to send:      1
      Bytes added:             956816
        - sent:                956788
        - failed to send:      28
    Client: Flow Monitor MonitorA
      Records added:           2119324114
        - sent:                2119324063
      Bytes added:             99608233358
        - sent:                99608230961
13 Replies 13
Mark Malone
hi looks ok in terms of config can you post the command output below , to see if the flows are generating in the router itself for netflow
show flow exporter statistics
Hi Mark,
here is the output:
Router2#show flow exporter statistics
Flow Exporter NTAexport:
  Packet send statistics (last cleared 00:09:50 ago):
    Successfully sent:         0                     (0 bytes)
    Client: Flow Monitor NTAmonitor
      Records added:           0
      Bytes added:             0
 match ipv4 tos
 match ipv4 protocol
 destination x.x.x.x
 source xxxxx
 record FLOW-RECORD
 exporter NetQos
        - sent:                11924002
        - sent:                1192400200
        - sent:                34171
        - failed to send:      1
      Bytes added:             956816
        - sent:                956788
        - sent:                2119324063
        - sent:                99608230961
Yes I can ping the PRTG(192.168.2.18).
Version: isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Let me try your config...
Thnaks
im using that version image too so its not the software just to rule it out
once i changed the version to 9....is ee this:
Router2#sh flow exporter  statistics
  Packet send statistics (last cleared 00:00:06 ago):
    Successfully sent:         2                     (292 bytes)
      Records added:           0
      Bytes added:             0
      Records added:           0
      Bytes added:             0
      Records added:           6
        - sent:                6
      Bytes added:             282
        - sent:                282
ok so it doesn't like the v5 command , can you just use v9 it works fine for us we dont have the v5 command set or is there a reason your trying to use v5 specifically for the collector ?
On all other IOS router i am using version 5...
Now i configured to version 9...
here are the statistics:
  Packet send statistics (last cleared 00:05:02 ago):
    Successfully sent:         201                   (26364 bytes)
      Records added:           0
      Bytes added:             0
      Records added:           0
      Bytes added:             0
      Records added:           536
        - sent:                536
      Bytes added:             25192
        - sent:                25192
But still PRTG is not showing anything
the prtg may only be set to see v5 packets , im not 100% on how that works i dont use that particular app , there may be options for netflow versions im not sure on that
very strange the other routers are working fine on the v5 export though, is there any difference in config or ios or platform with the working and this non working 4331
I have set the net-flow version 9 on PRTG.
All other router is IOS based(28XX and 29XX)...this is the first router with IOS-XE(4331..)
I will check the setting again on PRTG and come back here about the result...
So finally its working.
I needed to change the port..
For all other router with version 5 was using 9995 and now  used 2055 for version 9 and it worked.
Thanks mark.
ah very good , that's good to know thanks for posting that back
Here is my new config:
 match ipv4 tos
 match ipv4 protocol
 source Vlan6
 transport udp 9995
 exporter NTAexport
 record NTArecord
interface Vlan6
 ip flow monitor NTAmonitor output
  Packet send statistics (last cleared 00:01:38 ago):
      Records added:           0
      Bytes added:             0
Still Not working!!!!
