05-28-2012 04:49 AM - edited 03-04-2019 04:29 PM
I have configured eigrp routing on cisco 1941 ISR with two interfaces advertised. However i can not ping the router interface on g 0/0 but can ping the device and computers attached to that network. When i ping from the same network i'm able to ping the interface but not from anyway else. i can also ping the other devices on other network from g 0/0 attached hosts. How can i enable ping to this interface so that i start monitoring the network?
Below i have attached the network configurations for the router;
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxx
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO1941/K9 sn xxxxxxxx
username admin privilege 15 password 0 xxxxxxxxx
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description --connnecting LAN--
ip address 192.168.48.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description --Connecting Fiber-cloud--
ip address 10.11.0.48 255.255.255.192
duplex auto
speed auto
router eigrp 155
network 10.11.0.0 0.0.0.63
network 192.168.48.0
no ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password xxxxxxx
login local
transport input all
05-28-2012 04:55 AM
Cisco routers don't block icmp by default. We're probably going to need to know a little more about how you're set up.
1.) Are you trying to ping the 192.168.48.1 from a host on the 192.168.48.0/24 subnet or from a subnet off of the eigrp neighbor on the other side?
You should be able to ping g0/0 from a host on the 192.168.48.0/24 subnet unless there's something in the way blocking icmp traffic.
HTH,
John
05-28-2012 11:56 AM
thanks for the quick reply,i'm able to ping g0/0 from hosts sitting on 192.168.48.0/24 network but not from hosts sitting on the other networks i.e 10.11.0.0/26 network or other subnets,but able to ping devices sitting on 192.168.48.0/24 from these networks ,its just the g0/0 router interface i cant ping. there are no access lists configured on the router.
05-28-2012 01:50 PM
Can you post a diagram of how you're laid out? How many routers do you have? Can you post "sho ip route"?
