Cisco 1941 on gi0/0 - connected but no internet
johnorillo
Hi to all!
I am new in cisco, please anyone can you help me how to solve this problem.
Inside the router I can ping www.google.com but the laptop is connected on interface gi0/1 is not getting internet. I don't know what I'm missing.. below is the running-config.
Current configuration : 6094 bytes
version 15.1
hostname RYD-TYPSA-KINGFAHAD
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
ip source-route
no ip cef
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp pool TYPSA-KINGFAHD
network 192.168.2.0 255.255.255.0
domain-name TYPSA-KINGFAHD
dns-server 86.51.34.17 86.51.35.18
default-router 192.168.2.1
ip domain name yourdomain.com
ip name-server 86.51.34.17
ip name-server 86.51.35.18
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description < TO | MOBILY | MPLS >$ETH-WAN$
ip address 85.194.108.202 255.255.255.252
ip access-group 199 out
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description $ETH-LAN$
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
router bgp 65000
bgp router-id 192.168.104.202
bgp log-neighbor-changes
network 192.168.2.0
neighbor 192.168.104.201 remote-as 35819
neighbor 192.168.104.201 description < TO | MOBILY | MPLS >
ip default-gateway 85.194.108.201
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash
ip nat inside source list LAN_SUBNET interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 85.194.108.201
ip route 192.168.2.0 255.255.255.0 85.194.108.201
ip access-list standard LAN_SUBNET
remark CCP_ACL Category=2
permit 192.168.2.0 0.0.0.255
access-list 100 permit tcp any any eq 443
access-list 199 remark CCP_ACL Category=1
access-list 199 permit tcp any any
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 199 in
access-class 199 out
no login
transport input ssh
transport output ssh
line vty 5 15
login local
transport input all
scheduler allocate 20000 1000
end
mfurnival
Level 4
Level 4
On G0/0 you have an outbound access list 199 which only permits TCP. If you were on a PC on the LAN side you would not be able to resolve DNS names to IP addresses (DNS uses udp). Can you ping 8.8.8.8 from your PC on the LAN?
Can you also provide a "show ip route" please?
mfurnival
Level 4
Level 4
johnorillo
Hi mfurnival!
Thank you from your reply!
I removed access-list 199 and now I can ping 8.8.8.8 from my pc.
This is the ip route.
RYD-TYPSA-KINGFAHAD#sho ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 85.194.108.201 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 85.194.108.201
      85.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        85.194.108.200/30 is directly connected, GigabitEthernet0/0
L        85.194.108.202/32 is directly connected, GigabitEthernet0/0
      192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.2.0/24 is directly connected, GigabitEthernet0/1
L        192.168.2.1/32 is directly connected, GigabitEthernet0/1
I got internet now but so slow.. I supposed to get 2mbps, but when I did speedtest the result is 0.38mbps download.
Glad you are making progress. Contact your provider about the speed issue and see what they say.
I asked for a "show ip route" because there are some oddities in your config:
This line:
tells your router that your LAN subnet can be reached via your WAN gateway, It is ignored by the router because 192.168.2.0 is a connected network with a lower AD but I wonder what you were trying to do with this line.
Also you have a BGP statement that does not seem to be live.
Because you are internet facing on this router I would seriously consider beefing up the security on this router with some IOS firewall commands. Here is the design guide:
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5708/ps5710/ps1018/product_implementation_design_guide09186a00800fd670.html
Thanks for your help mfurnival!!! kudos to you man!
Appreciated it much!!! It did save a lot of my time today!
By the way, about my slow connection. I noticed that I had to lines of ip route, I just remove the ip route 192.168.2.0 255.255.255.0 85.194.108.201. Then leave this ip route 0.0.0.0 0.0.0.0 85.194.108.201, now I got the full speed.
