Cisco 1941 - PPOE / MTU / Fragmentation Issue
bytewize_ns
Hoing someone can see what is going on here..
I have a clients site that io have configured a layer 3 FTTP NBN connection, the ISP only support PPOE and no EoIP, I have set the virtual interface Dialer1 and configured everything as far as i'm aware it seems correct the link is up and the site is functional but I am experiencing fragmentation issues and inconsistent speeds and latency due to the misconfiguration somewhere..
Here is the config:
interface GigabitEthernet0/0
description Primary Physical LAN Interface
no ip address
ip virtual-reassembly in
duplex full
speed 1000
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
description Primary LAN Interface
ip nat inside
duplex auto
speed auto
interface Dialer1
description Primary Virtual WAN Interface
mtu 1492
ip address negotiated
ip access-group 100 in
no ip redirects
no ip proxy-arp
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname xxxxx
ppp chap password 0 xxxx
ppp pap sent-username xxxx password 0 xxxx
no cdp enable
When i run sh ip traffic:
IP statistics:
Rcvd: 39370 total, 37530 local destination
0 format errors, 0 checksum errors, 0 bad hop count
0 unknown protocol, 0 not a gateway
0 security failures, 0 bad options, 0 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 0 alert, 0 cipso, 0 ump
0 other
Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
25 fragmented, 110 fragments, 2 couldn't fragment
0 invalid hole
Bcast: 2696 received, 0 sent
When i run
rre-rt001#sh ip virtual-reassembly
GigabitEthernet0/0:
Virtual Fragment Reassembly (VFR) is ENABLED [in]
Concurrent reassemblies (max-reassemblies): 16
Fragments per reassembly (max-fragments): 32
Reassembly timeout (timeout): 3 seconds
Drop fragments: OFF
Current reassembly count:0
Current fragment count:0
Total reassembly count:0
Total reassembly timeout count:0
GigabitEthernet0/1:
Drop fragments: OFF
Total reassembly count:1
Cellular0/0/0:
Drop fragments: OFF
Dialer1:
Drop fragments: OFF
Total reassembly count:15107
Total reassembly timeout count:1
Mcast: 0 received, 0 sent
Sent: 45973 generated, 2369946 forwarded
Drop: 0 encapsulation failed, 0 unresolved, 0 no adjacency
0 no route, 0 unicast RPF, 0 forced drop
0 options denied
Drop: 0 packets with source IP address zero
Drop: 0 packets with internal loop back IP address
0 physical broadcast
Reinj: 0 in input feature path, 0 in output feature path
I contacted the ISP NOC and they said my config should work and they sent me the config from their side as well.
interface Dialer1
ip virtual-reassembly in max-reassemblies 512
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp chap hostname xxxxxxxxxxxx
ppp chap password xxxxxxxxxxxx
ppp ipcp header-compression ack
ppp ipcp dns request accept
ppp ipcp address required
end
description WAN
no ip address
ip flow ingress
ip flow egress
end
I have tried setting the ports to auto and manual on g0/0
I have tried setting ip tcp adjust-mss 1452 on both interfaces and also only on the internal
When i ping from the LAN side to test packet size I get:
C:\Users\administrator.CORP>ping 8.8.8.8 -f -l 1464
Pinging 8.8.8.8 with 1464 bytes of data:
Reply from 8.8.8.8: bytes=1464 time=23ms TTL=122
Reply from 8.8.8.8: bytes=1464 time=24ms TTL=122
Ping statistics for 8.8.8.8:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 23ms, Maximum = 24ms, Average = 23ms
C:\Users\administrator.CORP>ping 8.8.8.8 -f -l 1465
Pinging 8.8.8.8 with 1465 bytes of data:
Reply from 192.168.1.1: Packet needs to be fragmented but DF set.
Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
I have tried adding the exact same config as the ISP above and issue still persists..
Can someone please help me work out what i'm doing wrong..
Thanks..
Adrian
based on your ping results, try the values below:
interface Dialer1
mtu 1460
no ip redirects
no ip proxy-arp
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1420
dialer pool 1
no cdp enable
interface Dialer1
mtu 1460
no ip redirects
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
Hi George,
Thanks for your reply, I tried this and still getting fragmentation.
I have my dialer interface set to:
interface Dialer1
mtu 1460
no ip redirects
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname XXX
ppp chap password 0 XXx
ppp pap sent-username XXX password 0 XXX
no cdp enable
end
I am now getting
C:\Users\administrator.CORP>ping 8.8.8.8 -f -l 1433
Pinging 8.8.8.8 with 1433 bytes of data:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\administrator.CORP>ping 8.8.8.8 -f -l 1432
Pinging 8.8.8.8 with 1432 bytes of data:
Reply from 8.8.8.8: bytes=1432 time=23ms TTL=122
Minimum = 23ms, Maximum = 23ms, Average = 23ms
The CPU usage is not maxing out.
I am blocking ICMP
access-list 100 deny icmp any any echo log
As the MSS clamping is set, should this matter?
Thanks..
Adrian
@Georg Pauwen Thanks for confirming the correct config based on ICMP results. I worked the same answer out through calculation, in the end left my configuration in place and raised a ticket with the ISP to check their configuration.
They never told me what the resolution was was but something was changed and all working smoothly now.
