Cisco 1941 Router Nat Problem
Erkut Oztekin
Just to give one example on my local web server ip 192.168.1.237 i want to be outside adress port 80 direct to 192.168.1.237 port 80
"ip nat inside source static tcp 192.168.1.237 80 interface GigabitEthernet0/0 80"
and
"ip nat inside source static tcp 192.168.1.237 80 interface x.x.x.x 80 extendable"
i tried as, opened ports but not not direct
I thought it was server error. But both of these existing linksys E4200 router port forwarding is working with. In the same way as I did for the camera does not reach the DVR.
Firstly, I think you need to resolve the DNS server. I'm nat inside her like this;
"ip nat inside source static tcp 192.168.1.227 53 interface GigabitEthernet0/0 53"
Port 53 opened but not redirected
Do you think that might cause or DNS server needs to be done for something different?
My config file is;
http://pastie.org/9395740#
mgaven
Sorry, I don´t understand what do you want to do.
Are you NATting a port 80 to another port 80? Why?
Sorry my english is not good...
Port forwarding doesn’t work? İ want to redirect incoming traffic from port 80 to the web server (port 80)
You don´t need port forwarding for this, if you need what I think. You can try the next command instead what you posted:
ip nat inside source static 192.168.1.237 interface GigabitEthernet0/0
Same problem is my DVR i want to redirect incoming port 60000 to the 192.168.1.99 port 80
