Bookmark
Subscribe
1540
Cisco 1941 Router PPPoE ADSL Conf
hurolonen
I m getting the below debug log and can not get IP from my ISP. It is static IP address and there is modem in bridge mode for the adsl line. Can everyone please suggest what is missing?
Thank you in advance,
Below Conf and debug out put
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 2
end
chg-tr-ixxx-01-e-01#
chg-tr-ixxx-01-e-01#sh run int di2
Building configuration...
Current configuration : 482 bytes
interface Dialer2
bandwidth 512
ip address negotiated
no ip redirects
no ip proxy-arp
ip mtu 1492
encapsulation ppp
no ip route-cache cef
load-interval 30
dialer pool 2
dialer-group 2
ppp authentication chap pap callin
ppp chap hostname myusername
ppp chap password 7 050807011E4857080D04
ppp pap sent-username myusername@griddsl password 7 110A180B2816120D102B
end
We are getting below error in Debug logs
May  3 13:42:19.064 UTC: Vi2 PPP: Outbound cdp packet dropped, NCP not negotiated
Hello
you say its a static ip adddress but you have enabled the dailer int for dhcp?
can you post the whole config if the router?
also try turning off both devices then turn the modem back on first.
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
thanks for the reply pdriver,
this is the whole configuration. have you ever faced such behaviour before?
hi,
was it working before? have you tried reporting the incident to your SP?
