cisco 1941
tuấn
2 all
i have 1 question. cisco 1941 has NAT, RIPv1,v2???
idont see it in any document
Joseph W. Doherty
Feature support depends on the IOS version and feature set installed on the router. I.e. you would examine the documentation for the IOS version and feature set, installed, or to be installed, on your 1941.
in addition to Joseph's post, I think the lowest IOS version you can run on the 1941 is 15.0, which definitely supports both NAT and RIPv2 (both of which have been around for a very long time).
If you are unsure, post the output of 'show version'...
thanks for support
can you show me the socument anout ios that have feature NAT, RIP
