Cisco 1941W router LAN failing to access internet but router can ping www.google.com
wiltpe
I am new to cisco router and I am having problem making LAN able to access internet.
My LAN network is 192.168.2.x/24
My ISP's default gateway is 192.168.0.1
GigabitEthernet0/1 is the interface facing LAN
GigabitEthernet0/0 is the interface facing WAN
Can anyone help, what am I getting wrong?
version 15.1
hostname cisco
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$3Ng.$Ss8vhlESYljXeb9roSGEm/
enable password 24917468
no aaa new-model
clock timezone PCTime 8 0
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip source-route
no ip routing
no ip cef
ip name-server 168.95.1.1
ip name-server 192.168.0.1
license udi pid CISCO1941W-A/K9 sn FTX153282DN
license accept end user agreement
hw-module ism 0
username yfi privilege 15 secret 5 $1$s2oR$6PL4ZJRbeb1Diohz4PMK60
redundancy
interface Loopback0
no ip address
interface Embedded-Service-Engine0/0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet0/0
description $ETH-WAN$
ip address 192.168.0.99 255.255.255.0
ip nat outside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
no ip route-cache
shutdown
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
description $ETH-LAN$
ip address 192.168.2.1 255.255.255.0
ip nat inside
no ip route-cache
ip tcp adjust-mss 1452
duplex auto
speed auto
no mop enabled
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
no ip address
shutdown
interface Vlan1
no ip address
no ip route-cache
shutdown
ip default-gateway 192.168.0.1
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.0.1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.2.0 0.0.0.255 log
snmp-server community public RO
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
line vty 0 4
privilege level 15
password 24917468
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
You need to enable ip routing:
cisco#conf t
cisco(config)#ip routing
7 Replies 7
the 'log' keyword at the end of your access list kills your NAT. Remove that keyword and check if you get connectivity:
So, change:
to
Hi Georg,
I had removed "log" as suggested but still having the same problem. Any thoughts? I had also use Cisco CP to test connection and I am getting this Failure reasons:
Troubleshooting Results
Failure Reason(s) Recommended Action(s)
To test connectivity, Cisco CP tries to ping the configured DNS servers. However, there is no configured route to any of the DNS servers through the selected interface. Select 'User-specified' option or add a 'host specific/network specific/default' route through this interface and retest connection.
below is the revised configuration. I enabled 'ip routing' (this is the most important part missing, 'ip cef', and removed the 'default-gateway'. If that still doesn't work, try the following name servers:
ip name-server 8.8.8.8
ip name-server 8.8.4.4
version 15.1
hostname cisco
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
no ipv6 cef
ip source-route
ip routing
ip cef
hw-module ism 0
redundancy
interface Loopback0
no ip address
no ip address
no ip route-cache
shutdown
ip nat outside
no ip route-cache
duplex auto
speed auto
interface wlan-ap0
no ip address
no ip route-cache
shutdown
arp timeout 0
no mop enabled
no mop sysid
ip nat inside
no ip route-cache
duplex auto
speed auto
no mop enabled
no ip address
shutdown
interface Vlan1
no ip address
no ip route-cache
shutdown
ip http server
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line 67
no exec
transport input all
line vty 0 4
privilege level 15
password 24917468
login local
line vty 5 15
privilege level 15
login local
end
I had changed the configuration to the one you suggested but still not working, I had also change the ip-name-server as well and still not working. Below is the current configuration used:
version 15.1
hostname cisco
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
no ipv6 cef
ip source-route
no ip routing
no ip cef
hw-module ism 0
redundancy
interface Loopback0
no ip address
no ip address
no ip route-cache
shutdown
ip nat outside
no ip route-cache
duplex auto
speed auto
interface wlan-ap0
no ip address
no ip route-cache
arp timeout 0
no mop enabled
no mop sysid
ip nat inside
no ip route-cache
duplex auto
speed auto
no mop enabled
no ip address
shutdown
interface Vlan1
no ip address
no ip route-cache
shutdown
ip http server
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line 67
no exec
transport input all
line vty 0 4
privilege level 15
password 24917468
login local
line vty 5 15
privilege level 15
login local
end
cisco#conf t
Hi Georg,
Thank you so much for your time and effort. Really appreciate your help!
So you have full connectivity now ?
