cisco 2503 serial
ddufault
I've got an old 2503 router I want to use to connect to a T1 connection for a temporary solution. I just want to confirm that the serial interfaces on this router can support a full T1.
Thanks.
the serial port on your 2503 supports speeds up to 2.0 Mbps (T1/E1).
HTH,
GP
HTH,
GP
Perfect. Thanks alot.
comsats
well its a simple rule that a serial is by default support up to T1/E1, so it will work perfectly no worries mate
