Cisco 2511-RJ configuration help needed please!
gskhanna
I have a Cisco 2511-RJ with 16 async RJ-45 built in ports. I can't seem to get the thing to work.
I want to connect the rj-45 ports to the console ports of Cisco 6500 sup2s and sup720 routers.
A) what type of cable is needed? Roll over? or Straight Through? or Crossover?
B) My configuration below: I've tried multiple cables, configurations etc, with no luck. Please let me know if I'm missing something.
termserver#sh run
Building configuration...
Current configuration : 1027 bytes
version 12.3
service password-encryption
hostname termserver
boot-start-marker
boot-end-marker
enable secret 5 xxxx
no aaa new-model
ip subnet-zero
no ip domain lookup
ip host r1 2001 10.10.100.1
ip host r2 2002 10.10.100.1
ip host r3 2003 10.10.100.1
ip host r4 2016 10.10.100.1
interface Loopback0
ip address 10.10.100.1 255.255.255.0
interface Ethernet0
ip address 10.5.5.2 255.255.255.128
no ip mroute-cache
interface Serial0
no ip address
shutdown
ip default-gateway 10.5.5.1
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.5.5.1
line con 0
line 1 16
session-timeout 20
exec-timeout 0 0
transport preferred telnet
transport input all
transport output none
line aux 0
transport input all
speed 38400
flowcontrol hardware
line vty 0 4
exec-timeout 0 0
password xxx
login
transport input all
end
5 Replies 5
gskhanna
More information:
termserver# sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 0 1 0/0 -
1 TTY 9600/9600 - - - - - 4 0 0/0 -
2 TTY 9600/9600 - - - - - 7 0 0/0 -
3 TTY 9600/9600 - - - - - 4 0 0/0 -
4 TTY 9600/9600 - - - - - 0 0 0/0 -
5 TTY 9600/9600 - - - - - 0 0 0/0 -
6 TTY 9600/9600 - - - - - 0 0 0/0 -
7 TTY 9600/9600 - - - - - 0 0 0/0 -
8 TTY 9600/9600 - - - - - 0 0 0/0 -
9 TTY 9600/9600 - - - - - 0 0 0/0 -
10 TTY 9600/9600 - - - - - 0 0 0/0 -
11 TTY 9600/9600 - - - - - 0 0 0/0 -
12 TTY 9600/9600 - - - - - 0 0 0/0 -
13 TTY 9600/9600 - - - - - 0 0 0/0 -
14 TTY 9600/9600 - - - - - 0 0 0/0 -
15 TTY 9600/9600 - - - - - 0 0 0/0 -
16 TTY 9600/9600 - - - - - 1 0 0/0 -
17 AUX 38400/38400 - - - - - 0 0 0/0 -
* 18 VTY - - - - - 11 0 0/0 -
* 19 VTY - - - - - 17 0 0/0 -
20 VTY - - - - - 8 0 0/0 -
21 VTY - - - - - 4 0 0/0 -
22 VTY - - - - - 0 0 0/0 -
IOS (tm) 2500 Software (C2500-IS-L), Version 12.3(13a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 26-Apr-05 12:52 by ssearch
Image text-base: 0x0307D3B0, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c)XB1, PLATFORM SPECIFIC RELEASE SOFTWARE (fc1)
BOOTLDR: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c)XB1, PLATFORM SPECIFIC RELEASE SOFTWARE (fc1)
termserver uptime is 4 weeks, 7 hours, 52 minutes
System image file is "flash:c2500-is-l.123-13a.bin"
cisco AS2511-RJ (68030) processor (revision I) with 14336K/2048K bytes of memory.
Processor board ID 09295958, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
16 terminal line(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
when reverse telneting to the point either closes the session right away, or just sits there.
I tried the
int async 1
async dedicated command but to no avail also.
I've never used the 2511-rj version before.
Thanks for any help.
The cables from the 2511 can plug directly into the RJ console ports of Cisco equipment.
For devices that have 25 Pin or 9 pin RS232, the adapter headshells are properly pinned and should work with any changes.
You can extend the length to "reasonable" distances with straight-through UTP (like plug it into a panel and using structured cabling infrastructure to get to the console port).
Make sure you have the 'Transport Input' (i.e., Transport Input Telnet) command to set the type of traffic you expect to see (and want to accept) for the port.
You also want to make sure the flow control parameters are properly set (generally disabled / off / inactive).
Good Luck
Scott
I'll give it a shot tomarrow. 1 thing to note, that this is a 2511-RJ and as such their are only RJ-45 ports physically on the device, and no 'cables' such as the octal cable that is normally with a 2511.
I'll check with the transport settings to see if it helps.
GURPREET
I would suggest that you add this to the configuration of the lines used for reverse telnet:
no exec
Give it a try and tell us if it hellps.
Rick
Rick
jmohlmaster
You will need to use standard rollover cables to go from the 2511-RJ to the supervisors, just as you would on a PC with a null-modem adapter.
Jarod
