Cisco 2514 Router
desybrooks
Hi All,
I am new to this site so appologies if I am in the wrong place.  I have just bought a 2514 router to start my CCENT study's.  When I turn on my router and connect via console through TeraTerm I get the following text and then I cant do anything.  Can someone point me in the right direction.
System Bootstrap, Version 5.0(6), RELEASE SOFTWARE
Copyright (c) 1986-1994 by cisco Systems
2500 processor with 1024 Kbytes of main memory
F3: 3834088+95972+196644 at 0x3000060
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) 3000 Software (IGS-I-L), Version 11.1(24a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Fri 09-Mar-01 19:43 by pnicosia
Image text-base: 0x03020728, data-base: 0x00001000
%SYS-3-BADRESID: Clock hardware returned bad residual 0cisco 2500 (68030) processor (revision C) with 1024K/1024K bytes of memory.
Processor board ID 01510459, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
2 Ethernet/IEEE 802.3 interfaces.
2 Serial network interfaces.
32K bytes of non-volatile configuration memory.
4096K bytes of processor board System flash (Read ONLY)
mfurnival
Level 4
Level 4
Thanks for the quick rspons, unfortunaltley when the router boots and I get the prompt "Press return to get started" nothing happens
Did you read those links? You need to break into ROMMON mode and install a new IOS. If it still does not work after that you might be looked at dead hardware.
