cisco 2522 router bandwidth sharing
imnilesh
Hi all;
i have cisco 2522 rtr; and on ethernet we have two ip, one is 10.155.146.xxx and 10.194.0.xxx(secondary).
now i want to do bandwidth sharing between this two ip which assign to ethernet. which will share my serial link of 64 kbps as 60 % and 40 %. is it possible. if yes then pls help me to do it.
thanks in advance.
nil
Hello Nil,
you could try and configure rate limiting on the serial interface, the interface configuration would look something like this:
interface Serial0
rate-limit output access-group 101 40000 7500 15000 conform-action transmit exceed-action drop
access-list 101 permit ip 10.155.146.0 0.0.0.255 any
This would limit traffic on your serial interface coming from IP address space 10.155.146.0/24 to 40000kbps (which is not exactly 60%, but the increments have to be 8000), the rest would be available for the other address space, 10.194.0.0.
Check this link to the command reference:
rate-limit
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/qos_r/qos_q1g.htm#wp1080850
HTH,
GP
hi gp;
thanks for ur reply but its not taking this command on my router here is show version of my router:
IOS (tm) 2500 Software (C2500-IS-L), Version 12.0(28), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 14-Jan-04 06:19 by nmasa
Image text-base: 0x0303E2BC, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFTWARE (fc1)
BSILCHNKUBER uptime is 3 weeks, 4 days, 3 hours, 4 minutes
System restarted by power-on
System image file is "flash:c2500-is-l.120-28.bin"
cisco 2522 (68030) processor (revision N) with 6144K/2048K bytes of memory.
Processor board ID 17286838, with hardware revision 00000003
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
8 Low-speed serial(sync/async) network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
//nil
