Cisco 2600 Access Point with Trunk link to Cisco 3750-G
Hamidsattarrana
I wanted to configure trunk link between AP and Cisco Switch. When i make the link trunk then I am not able to ping the Switch.
Can someone help me configuring Access Point.
We have only 1 vlan i.e. 300 and want to configure SSID for this VLAN on Cisco 2600 Access point.AP, Cisco, Erro
Thanks & Regards,
Hamid Sattar
11 Replies 11
Hamidsattarrana
I am using this guide to configure it. But it's not working. Here is the link to guide.
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/service-set-identifier-ssid/116118-configure-ap-ssid-ios.html
Hope you looking to have Autonomous AP with a single device? If yes try
Below Steps help you :
1. Do you have Right IOS image to configure Autonomous AP?
2. Connect the console cable to AP
3. Reset to Factory Default AP
4.  connect the laptop with IP address 10.0.0.10 (configured)
5. configure the AP
 with IP address example : 10.0.0.1 255.255.255.0
no shutdown
  • Test the connection by pinging: ping 10.0.0.10
  • Upload the image from the TFTP server of your laptop to the AP:
  •  archive download-sw /force-reload /overwrite tftp://10.0.0.10/image.tar
Follow below Guide :
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3/cg15-3-3-chap4-first.html
BB
Sandeep Choudhary
First check whcih image you have:
  • k9w7 - autonomous (or "site survey") IOS
  • k9w8 - full lightweight IOS/AP-COS (this is what is bundled in the WLC .aes image, and is factory installed on "mesh" APs)
Normally....
Local mode AP must be connected to access ports.
Autonomous mode AP must be connected to trunk port.
Dont forget to rate helpful posts
I am using this IOS image
Cisco IOS Software, C2600 Software (AP3G2-K9W7-M), Version 15.2(4)JB6, RELEASE SOFTWARE (fc1)
When I configure Trunk link on switch I am not able to ping it. Everything works fine if I don't make that link as Trunk Link.
is there any specific reason, why you want to configure it as trunk port ?
No. But I want to test it and configure it.
first check it has leighweight image or autonomous ?
I think its Autonomous based
BVI1 192.168.32.47 YES NVRAM up up
Dot11Radio0 unassigned YES NVRAM administratively down down
Dot11Radio1 unassigned YES NVRAM administratively down down
GigabitEthernet0 unassigned YES NVRAM up up
As you can see I have above interfaces. Dot11Radio0 is for 2.4GHz and Dot11Radio1 is for 5Ghz.
Vlan in our Netork: 300
Native Vlan: 1
Can someone post configurations so that I can make trunk link between Access Point and Switchport.
