Cisco 2612 routing / bridge between token ring and ethernet
Gypsy Dave
Hi guys,
I've got a Cisco 2612 router and trying to route traffic between my Ethernet network (192.168.1.0/24)  and TokenRing network (192.168.2.0/24). I'm trying to create a bridge between both networks.
The router has the interface Ethernet0/0 configured as 192.168.1.101 and the TokenRing0/0 interface configured with 192.168.2.1.
On the actual router I can ping both interfaces do I need to setup a static route? If so how?
25 Replies 25
Harold Ritter
Hi @Gypsy Dave ,
You do not need a static route, as the router is directly connected to both interfaces. Just make sure that devices on these two subnets are configured with a default gateway corresponding to the router respective interface IP address and you should be able to ping from the ethernet to the token-ring devices and vice versa.
Hi Harold Ritter Do I need to config a gateway per interface? I can ping the device on the token ring interface from the router and it gets assigned an ip from the IP helper I've created but I can't telnet to it or trace route it. I get a  "Destination unreachable; gateway or host down" seems like it cant find the path to that device.  Also my firewall can ping the token ring interface but not the device on the token ring side. Something is not correct.
--> On the actual router I can ping both interfaces do I need to setup a static route? If so how?
Not really sure what you are after. You can assign an IP address to the Token Ring interface, and both interfaces should be able to talk to each others. Do you have an actual TokenRing network attached ?
ok great thanks for the reply. I just need to work out how to create a route on one of the older machine so I can reach the token ring network via its ethernet card.
@Georg Pauwen yep I've got a real token ring network connected to it. I've old MSDOS devices on the Token ring side and modern MacOs and Windows on the ethernet side.
Gypsy Dave
So the current problem is clients on the Ethernet network can only ping the Cisco 2600 router's ethernet and token ring interface. I can't ping the clients on the Token ring network.
Computers on the token ring network can ping the Cisco 2600 token ring interface but not the ethernet interface and clients on the ethernet network.
I've seen this other posting that seems like a simular problem and talks about source-bridge but my 2600 does not have that command?
https://community.cisco.com/t5/switching/routing-between-token-ring-and-ethernet/td-p/1068716
Here is my config. It looks like its a source route bridging command configuration I'm missing?
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname BRI-TOKEN
enable secret 5 *********
enable password **********
no ip subnet-zero
no ip routing
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp pool TOKENPOOL
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 192.168.2.1
   netbios-name-server 192.168.2.1
bridge crb
process-max-time 200
 ip address 192.168.1.101 255.255.255.0
 no ip directed-broadcast
 no ip route-cache
 no ip mroute-cache
 bridge-group 1
interface Serial0/0
 no ip address
 no ip route-cache
 no ip mroute-cache
 shutdown
 no fair-queue
interface TokenRing0/0
 ip address 192.168.2.1 255.255.255.0
 ip helper-address 192.168.2.1
 no ip route-cache
 ring-speed 16
 bridge-group 1
interface Serial0/1
 no ip address
 no ip route-cache
 no ip mroute-cache
 shutdown
ip classless
no ip http server
snmp-server engineID local 00000009020000B064263AA0
snmp-server community public RO
bridge 1 protocol ieee
bridge 1 bitswap-layer3-addresses
 bridge 1 route ip
line con 0
 transport input none
line aux 0
line vty 0 4
 password ******
 login
no scheduler allocate
end
Thanks for posting the configuration. There are several things that we might want to talk about. But the most important issue in the config is this
no ip routing
Since you have one subnet on the Ethernet and a different subnet on the Token Ring you want to route between the subnets. But "no ip routing" disables routing. Remove that line and let us know if the behavior changes.
The issue here is that your configuration has some elements of a solution based on routing and some elements of a solution based on bridging. You should try to accomplish one or the other, but not both.
The solution based on routing is more simple and more robust. A solution based on bridging is more complex. Think about what you really want  and if it is the solution based on bridging we can make some suggestions about how to accomplish that.
Rick
Hi Rick,
Thanks for responding. I've removed that line by using the command "ip routing" and still have the same problems. From what I read I need to setup Source Route Bridging but I think my iOS version does not support it as I don't have the commands. Can this be done then via ip routing? What am I' missing?
I think you need an IOS that supports DEC in order to be able to configure SRB.
I wonder if just IRB can accomplish what you want (all Ethernet and Token Ring PCs would be in the same subnet, but at least you would have connectivity):
version 12.0
hostname BRI-TOKEN
no ip subnet-zero
--> bridge irb
no ip address
no ip route-cache
no ip mroute-cache
--> bridge-group 1
interface Serial0/0
no ip address
no ip route-cache
no ip mroute-cache
shutdown
no fair-queue
no ip address
no ip route-cache
ring-speed 16
--> bridge-group 1
interface Serial0/1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
--> interface BVI1
--> ip address 192.168.2.1 255.255.255.0
ip classless
no ip http server
--> bridge 1 protocol ieee
--> bridge 1 route ip
line con 0
line aux 0
line vty 0 4
password ******
login
end
Thanks for that. I'm a little confused. How will this route between the ethernet 192.168.1.0/24 and token ring 192.168.2-0/24 subnets?
Edit: Just read above again. I could try to move all the devices to one subnet to test. If I have a DHCP server on the ethernet side will the token ring network be able to get an ip address from it?
in the suggested config, the DHCP server (pool) would serve both the Ethernet and the Token Ring clients...
ok I've changed everything over to the subnet 192.168.1.0/24 And the devices on the token ring network with static ip address can now ping some device on the ethernet network but not everything like the internet router/firewall located at 192.168.1.1 (ping is enabled on it)?
The devices on the token ring network that are configured as dynamic IP can't reach the DHCP server which is on the router/firewall at 192.168.1.1. I've removed the IP helper commands (see bellow) so that the devices use the main DHCP server on the ethernet side.
version 12.0
service password-encryption
hostname BRI-TOKEN
enable password 7 *****
ip subnet-zero
bridge irb
 no ip address
 no ip route-cache
 no ip mroute-cache
 bridge-group 1
interface Serial0/0
 no ip address
 no ip mroute-cache
 shutdown
 no fair-queue
 no ip address
 no ip route-cache
 no ip mroute-cache
 ring-speed 16
 bridge-group 1
interface Serial0/1
 no ip address
 no ip mroute-cache
 shutdown
interface BVI1
ip classless
ip http server
 bridge 1 route ip
line con 0
line aux 0
line vty 0 4
 password 7 ******
 login
end
I think the 'bridge 1 bitswap-layer3-addresses' line is only needed for Source Route Translational Bridging. Not sure what if any effect this has in IRB, but remove that line anyway...
Yeah I did remove that and the same issues. Token ring devices can't reach 192.168.1.1 (DHCP or ping) and they can't reach ping to some ethernet devices.
Do I need to declare the router/firewall (192.168.1.1) as a gateway somewhere in the config?
your current configuration is different from the one I suggested/posted earlier.
Either way, if this is still in your configuration:
interface BVI1
Then this (192.168.1.101) must be the default gateway for all Ethernet and Token Ring clients...
