Cisco 2800 Config
Hello everyone,
I've adopted a Cisco 2800 series router as part of a change of IT contract, and I'm trying to reconfigure for LAN to WAN access.
I've come up with the following configuration, but I'm a little uneasy as I've never really worked with one of these before, especially one with an ADSL HWIC as opposed to the ISR's which I usually use.
Current configuration : 4594 bytes
version 12.4
hostname gateway
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 encryptedsecret
no aaa new-model
dot11 syslog
no ip source-route
ip cef
vtp version 2
username administrator privilege 15 secret 5 encryptedsecret
archive
 log config
  hidekeys
interface FastEthernet0/0
 ip address 192.168.0.1 255.255.240.0
 duplex full
 speed auto
 no mop enabled
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface ATM0/0/0
 no ip address
 no ip unreachables
 no atm ilmi-keepalive
 pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Dialer0
 ip address negotiated
 ip mtu 1452
 ip nat outside
 ip virtual-reassembly
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap calling
 ppp chap hostname username@isp.net
 ppp chap password 0 IspPassword
 ppp pap sent-username username@isp.net password 0 IspPassword
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.0.0 0.0.15.255
control-plane
line con 0
line aux 0
line vty 0 4
 privilege level 15
 login local
 transport input telnet ssh
 transport output telnet ssh
scheduler allocate 20000 1000
end
It would be fantastic if someone could please check the above me and let me know of any issues, I'm especially worried about the dialers, ATM, dialer-group etc.
Cheers,
Anthony
Peter Paluch
Hi Anthony,
A couple of comments:
  1. You are missing the ip nat inside on your Fa0/0 interface. Without it, the NAT won't work.
  2. There are basically two different modes of running PPP over DSL access, named PPP over ATM (PPPoA), and PPP over Ethernet (PPPoE). They differ in encapsulation and in the procedures required to bring the connection up. Your current configuration is correct for PPPoA and that is what puzzles me: PPPoA is used relatively infrequently. PPPoE is much more popular. So I suggest double-checking with your ISP whether this access is really PPPoA and not PPPoE. In the case the access is PPPoA then the ATM/DSL interface is fine, however, you shoudl remove the ip mtu 1452 command from your Dialer0 interface as PPPoA does not require the MTU to be modified.
    If, however, the access is PPPoE then both ATM0/0/0 and Dialer0 will need to be slightly updated: the following commands are the ones that should be entered to have the interfaces modified to the intended state:
    interface ATM0/0/0
     pvc 8/35
      no dialer pool-member 1
      no encapsulation aal5mux ppp dialer
      pppoe-client dial-pool-number 1
      exit
     exit
    interface Dialer0
     no ip mtu
     mtu 1492
     ip tcp adjust-mss 1452
  3. Remove the dialer-group 1 and ppp authentication chap pap callin commands from the Dialer0 interface as they are inappropriate for your deployment.
Of course please feel welcome to ask further!
Best regards,
Peter
5 Replies 5
Peter Paluch
Hi Anthony,
    interface ATM0/0/0
     pvc 8/35
      exit
     exit
    interface Dialer0
     no ip mtu
     mtu 1492
Best regards,
Peter
I completely missed that, thanks!
In regards to PPPoE v PPPoA, I think the service supports both. As we've run both PPPoA and PPPoE on the same service line. I've done some research and PPPoA looks to be slightly quicker so I might stick with that. ISP is Telstra Business in Australia, so we're a little behind the rest of the world.
How is the ppp authentication not required? Doesn't that state the type of authentication to the ISP?
Also how does the Cisco know that dialer0 maps to the ADSL HWIC?
Here's the new config after making the changes you suggested:
 description LAN Network
 ip nat inside
 duplex full
 speed auto
 no mop enabled
interface ATM0/0/0
 no ip address
 no ip unreachables
 pvc 8/35
interface Dialer0
 ip nat outside
 encapsulation ppp
 dialer pool 1
Thanks for your in depth reply, I'm sure your assistance is going to make things much smoother on deployment day!
Cheers,
Anthony
Hi Anthony,
It is indeed possible that the service provider supports both PPPoA and PPPoE. However, I doubt that they support in on the same ATM PVC, that is, both over PVC 8/35. You may want to double-check this with your provider. In any case, yes, the PPPoA carries significantly less overhead (no SNAP headers, no PPPoE headers) and has no MTU issues, so if you can deploy a PPPoA solution, go for it.
Aaah, don't get me started on some backwardisms my country :-P
Not at all. First, you cannot force your ISP to authenticate you using a particular method. It is the ISP who will request your router to authenticate using a specific method, and your router can either comply or refuse, but it cannot tell the ISP beforehand what method it wants to be authenticated with.
Second, the ppp authentication ... callin command is actually totally the opposite of what you expect: It tells your router to authenticate the ISP if it calls you! This fact appears to confuse many people and there have been several threads here already where we went into depth about the unnecessity of this command. I suggest you read the following thread:
https://supportforums.cisco.com/discussion/11285241/how-do-i-setup-ppp-dialer-present-empty-credentials
This is because either with PPPoA or PPPoE, the PVC 8/35 on ATM0/0/0 is acting as a "dialable" interface in dialer pool 1, and the Dialer0 is configured to use any interface from the dialer pool 1 to make the actual call - hence the association.
Looks good to me.
Best regards,
Peter
Turns out that they do in fact support PPPoA and PPPoE on 8/35.
20/4 is a good speed here, we'll get away from copper one day!
Did some research as you suggested, and you're right; completely opposite of what I expected.
This is because either with PPPoA or PPPoE...
Perfect, thanks for explaining :)
Looks good to me.
It worked! Thanks for all your help!
Anthony,
Glad to have helped! Thanks for letting me know :)
Best regards,
Peter
