cisco 2800 ISR
shaikh ibrahim
         Hi ,
             How may modules  can be plugging in cisco 2800 router  .there are two uplink ports on the back of router having two internet connection from different service provider and now i have one connection for SIP ..any idea how i can connect??
SHIB
mvsheik123
Level 7
Level 7
What exact model? Check the below link ...
http://www.cisco.com/en/US/products/ps5854/prod_models_comparison.html
hth
MS
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Besides the exact 2800 model, what kind of media do you now use and want to expand to?
If this is Ethernet, the 2800s normally can't sustain the built-in interfaces at full bandwidth.  This being so, it makes little sense to add Ethernet ports to it.  If additional Ethernet ports are logically required, you can often VLAN tag them to/from the 2800.
