GRE Tunnel as a "in order delivery" method
aviyoshi10
i have 2 sites connected via 4 wan links in a point to point. i want to equally distribute the traffic on the 4 links - using ip cef per-packet load sharing.
the problem will be that i will get packets out of order.
i though of using a gre tunnel as a solution for that,
a single gre tunnel which will see the remote gre tunnel through the 4 wan links and send each packet to different wan link. at the remote site single gre will collect the traffic from the 4 links and use the sequence number on its header to make the "in order delivery" toward the application.
is this can work ?
if it can, how much traffic this kind of solution can forward ?
thanks,
Avi.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Would MLPPP be possible?  (NB: you didn't describe the WAN technology or network device types.)
