CISCO 2800 Series Router Boot Error
GaeMi
When I boot the router, I get the following error.
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Initializing memory for ECC
c2821 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x35a13cc
Self decompressing the image : ##################################################################################################################################################################################################################################################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
0003E8          0X00474800 C2821 Mainboard
                0X000021B8 Onboard USB
                0X002C29F0 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X0094A3A8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 10Mb.
Using 1 percent iomem. [10Mb/512Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 15.1(4)M3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Dec-11 16:21 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 1.0) with 514048K/10240K bytes of memory.
Processor board ID FHK1142F3Y7
2 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
no logging discriminator
% Incomplete command.
Logging of %SNMP-3-AUTHFAIL is disabled
logging queue-limit esm 0
% Invalid input detected at '^' marker.
logging buffered 0 debugging
ipc holdq threshold upper 0
ipc holdq threshold lower 0
cef table vrf tree IPv6 type RTREE
cef table output-chain build favor default
ip nbar port-map h323 tcp 1300 1718 1719 1720 11000 - 11999
ip nbar port-map custom-10 udp
ip nbar port-map custom-10 tcp
ip nbar port-map custom-09 udp
ip nbar port-map custom-09 tcp
ip nbar port-map custom-08 udp
ip nbar port-map custom-08 tcp
ip nbar port-map custom-07 udp
ip nbar port-map custom-07 tcp
ip nbar port-map custom-06 udp
ip nbar port-map custom-06 tcp
ip nbar port-map custom-05 udp
ip nbar port-map custom-05 tcp
ip nbar port-map custom-04 udp
ip nbar port-map custom-04 tcp
ip nbar port-map custom-03 udp
ip nbar port-map custom-03 tcp
ip nbar port-map custom-02 udp
ip nbar port-map custom-02 tcp
ip nbar port-map custom-01 udp
ip nbar port-map custom-01 tcp
no ip cef accounting
no ip sctp authenticate init
no ip sctp authenticate init-ack
no ip sctp authenticate shutdown-complete
no ip sctp authenticate authentication
ipv6 nd ns-interval 0
ipv6 nd dad time 0
multilink virtual-template 0
 WARNING!: secondary export device is same as primary
%Text Relay needs to be enabled before the options being configuredError.  Must have active or default circuits defined to change this value.
Port Change will be effective once the H.323 service is re-started
Alternate endpoint hunt enabled for all cause codes
  no h225 plus-digit-passthru-called
  no h225 plus-digit-passthru-calling
Port number already in use.
  listen-port secure  5061
Warning: Configuring media inactivity detection to avoid hung calls is highly recommended.
ip tcp mss 0
ip tftp min-timeout 3000
buffers header min-free 128
buffers header initial 0
buffers fastswitching min-free 128
buffers fastswitching initial 0
%GigabitEthernet0/0 is a static pool and cannot be tuned
%GigabitEthernet0/1 is a static pool and cannot be tuned
Is there a way to fix the error without clearing the settings?
2 Accepted Solutions
it looks like your router is trying to load a configuration that contains lines the IOS version doesn't support. I would take out the lines that generate the error messages one by one once the configuration has been loaded...
The router is loaded with VOICE feature set. NBAR is IP Services feature set.
Thank you for your reply.
After the text relay, it should boot normally but it did not.
I tried several methods, but eventually I had to clear the settings before I could boot.
