CISCO 2801 AND DEVICES
rizosv
Hello, i trie to connect some devices in this router and when i establing a connection after several minutes the disconects
I enter an ip which excluded from dhcp but i dont know what else to do. Also the arp table doesnt show anything wrong. any suggestion?
Thank you in advance.
Building configuration...
Current configuration : 3828 bytes
version 15.1
hostname Ford
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.28.1 192.168.28.15
ip dhcp excluded-address 192.168.28.34
ip dhcp pool PC's
network 192.168.28.0 255.255.255.128
default-router 192.168.28.1
domain-name intern.pazaropoulos.gr
netbios-node-type h-node
dns-server 192.168.0.2 192.168.0.3
lease 7
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2801 sn FCZ10282111
username fxxxxx privilege 15 password xxx
redundancy
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key DmVpn!123# address 0.0.0.0 0.0.0.0
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode transport
crypto ipsec profile CiscoCP_Profile1
set transform-set ESP-3DES-SHA
interface Loopback100
description **ADSL BACKUP ***
ip address 62.1.56.113 255.255.255.255
interface Tunnel0
bandwidth 1000
ip address 172.20.1.3 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication PZDMVPN1
ip nhrp map multicast 195.97.78.36
ip nhrp map 172.20.1.1 194.219.58.98
ip nhrp map multicast 194.219.58.98
ip nhrp map 172.20.2.1 195.97.78.36
ip nhrp network-id 100000
ip nhrp holdtime 360
ip nhrp nhs 172.20.1.1
ip nhrp nhs 172.20.2.1
ip nhrp registration no-unique
ip tcp adjust-mss 1360
delay 1000
tunnel source Loopback100
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile CiscoCP_Profile1
interface FastEthernet0/0
ip address 192.168.28.1 255.255.255.128
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
description *** CONNECTION WITH FORTHNET ***
ip address 194.219.3.114 255.255.255.252
speed 100
full-duplex
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
interface ATM0/1/0.1 point-to-point
pvc 8/35
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface Dialer0
description *** ADSL_BACKUP CONNECTION WITH FORTHNET ***
ip address negotiated
ip nat outside
encapsulation ppp
no ip route-cache
ip tcp header-compression
ip tcp adjust-mss 1452
load-interval 30
carrier-delay 60
dialer pool 1
dialer idle-timeout 30
dialer fast-idle 15
dialer wait-for-line-protocol 30
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname fordheadquarter.at
ppp chap password 0xxxxxxxxxxxxxxxxxx
ppp pap sent-username fxxxxxxxxxxxxxxxxxxxxxxxxx
no cdp enable
router eigrp 65002
network 172.20.1.0 0.0.0.255
network 172.21.0.0 0.0.0.255
network 192.168.28.0 0.0.0.127
router eigrp 200
distribute-list 10 out
network 194.219.3.112 0.0.0.3
redistribute connected
passive-interface Dialer0
ip forward-protocol nd
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer0 200
ip route 93.174.121.59 255.255.255.255 172.20.1.1
ip route 136.1.0.0 255.255.0.0 172.20.1.1
ip route 136.2.12.190 255.255.255.255 172.20.1.1
ip route 195.167.10.55 255.255.255.255 172.20.1.1
logging esm config
access-list 10 permit 194.219.3.112 0.0.0.3
access-list 10 permit 62.1.56.112 0.0.0.7
dialer-list 1 protocol ip permit
control-plane
mgcp profile default
line con 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 120 0
login local
transport input all
scheduler allocate 20000 1000
end
13 Replies 13
Sergey Lisitsin
Can you please elaborate on what and how you connect to the router and also what do you mean by disconnects. Can you show some output from the router, like "show ip route", "show ip eigrp nei" etc.
i connect a network printer and a tax machine with static ip 192.168.28.3 and 192.168.28.4.
When i search and connect the printer i do some printing and several minutes later the printer status sais disconect.
sh tcp brief all
TCB Local Address Foreign Address (state)
6A454B74 ::.80 *.* LISTEN
6A45407C 0.0.0.0.80 *.* LISTEN
FordPetrouRali#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is 194.219.3.113 to network 0.0.0.0
D*EX 0.0.0.0/0 [170/540160] via 194.219.3.113, 7w0d, FastEthernet0/1
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
D 10.2.1.0/28 [90/2818816] via 172.20.1.1, 1w1d, Tunnel0
D 10.2.1.32/28 [90/3097600] via 172.20.1.5, 5d03h, Tunnel0
D 10.39.161.128/27 [90/2818816] via 172.20.1.1, 1w1d, Tunnel0
62.0.0.0/32 is subnetted, 1 subnets
C 62.1.56.113 is directly connected, Loopback100
93.0.0.0/32 is subnetted, 1 subnets
S 93.174.121.59 [1/0] via 172.20.1.1
S 136.1.0.0/16 [1/0] via 172.20.1.1
136.2.0.0/32 is subnetted, 1 subnets
S 136.2.12.190 [1/0] via 172.20.1.1
172.20.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.20.1.0/24 is directly connected, Tunnel0
L 172.20.1.3/32 is directly connected, Tunnel0
192.168.0.0/25 is subnetted, 2 subnets
D 192.168.0.0 [90/2818816] via 172.20.1.1, 1w1d, Tunnel0
D 192.168.0.128 [90/2818560] via 172.20.1.1, 1w1d, Tunnel0
192.168.1.0/25 is subnetted, 2 subnets
D 192.168.1.0 [90/2818816] via 172.20.1.1, 1w1d, Tunnel0
D 192.168.1.128 [90/2818816] via 172.20.1.1, 1w1d, Tunnel0
D 192.168.3.0/24 [90/3074560] via 172.20.1.7, 04:21:04, Tunnel0
192.168.4.0/27 is subnetted, 1 subnets
D 192.168.4.0 [90/3097600] via 172.20.1.5, 5d03h, Tunnel0
192.168.28.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.28.0/25 is directly connected, FastEthernet0/0
L 192.168.28.1/32 is directly connected, FastEthernet0/0
D 192.168.254.0/24 [90/2818816] via 172.20.1.1, 1w1d, Tunnel0
D 192.168.255.0/24 [90/2818816] via 172.20.1.1, 1w1d, Tunnel0
194.219.3.0/24 is variably subnetted, 2 subnets, 2 masks
C 194.219.3.112/30 is directly connected, FastEthernet0/1
L 194.219.3.114/32 is directly connected, FastEthernet0/1
195.167.10.0/32 is subnetted, 1 subnets
S 195.167.10.55 [1/0] via 172.20.1.1
show ip eigrp nei
EIGRP-IPv4 Neighbors for AS(65002)
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
0 172.20.1.1 Tu0 12 1w1d 12 200 0 1962
EIGRP-IPv4 Neighbors for AS(200)
(sec) (ms) Cnt Num
0 194.219.3.113 Fa0/1 11 13w6d 1 200 0 6500
OK, are what machine do you ping the printer from? What IP address? If it is in the same network, then the router is not even used.
in several machines that have ip from dhcp . 192.168.28.59 and similar. Is it a port issue?
No, that has nothing to do with the router. I presume they are all connected to the same switch? Or are they connected to a switch module on the router?
Yes correct in the same switch not on the routers switch module
Well, in that case the communication between printer and PCs is not going via the router. Router has nothing to do with that.
you have a point but as i see in switch there no clue for this problem. Do you have any suggestions how to continue?
thank you.
show running-config
Current configuration : 2487 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname FordRentisSW1
username administrator privilege 15 password 7 0227234F0A264E
no aaa new-model
ip subnet-zero
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
description Patch39 - Linksys WiFi
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.28.5 255.255.255.128
no ip route-cache
no ip http server
control-plane
banner motd ^CCC
* W A R N I N G *
* UNAUTHORIZED ACCESS IS SUBJECT TO CIVIL-CRIMINAL PENALTIES *
* ALL ACCESS TO THIS SYSTEM IS LOGGED WITHOUT FURTHER NOTICE *
^C
line con 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
no login
end
It looks like you've got a simple flat network with only one VLAN. Printers do sometimes go into power saving mode and turn off the network card. Rebooting the printer should help. However, if it goes to sleep mode every few minutes, rebooting it every time is not a solution. Try to have a look in the printer's settings and find the idle timeout. Increase it and see if that helps.
unfortunately i have done all the above with no result
OK, another thing to try is to run a continuous ping from a server to the printer. That might keep the NIC awake.
i have done but with no result some times ping some times not. i think the problem is here.  can i permit a specific ip 192.168.28.3 for example in the network?
show access-list
Standard IP access list 10
10 permit 194.219.3.112, wildcard bits 0.0.0.3 (2 matches)
20 permit 62.1.56.112, wildcard bits 0.0.0.7 (4 matches)
You can permit it, but I doubt that this is the issue. If it was denied, you would never get access.
