Cisco 2811 can't see HWIC-1CE1T1-PRI
steve.kerr
Hi, I have a HWIC-1CE1T1-PRI in a Cisco 2811 running IOS c2800nm-advipservicesk9-mz.124-18b.bin.
When I enter the "card type E1 0 0" command (it is in WIC 0 slot) I get the following response:
SYINDEV01RW02(config)#card type e1 1 0
% Invalid input detected at '^' marker.
Also the show inventory or show hardware commands do not appear to show this card at all.
Am I missing something here or does this look like the card is faulty?
Jon Marshall
Steve
You need a minimum IOS of 12.4(20)T for this card, see Table 2 of the following doc -
https://www.cisco.com/en/US/prod/collateral/modules/ps2797/product_data_sheet0900aecd80710c88_ps5949_Products_Data_Sheet.html
so you need to upgrade your IOS.
Jon
OK, thanks for the response, will upgrade the IOS as you suggest. I did wonder if this was an issue.
