Cisco 2811 Frame Relay Hardware Compression
pankajjankee
Does the Router C2811 with VPN/SSL module support hardware compression for frame relay??
the command "show pas caim 0" say unrecognised command and "show compress" outputs only software compression.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(9)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 07-Jun-07 04:42 by prod_rel_team
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FCZ112970F6
2 FastEthernet interfaces
2 Serial(sync/async) interfaces
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
purohit_810
Level 5
Level 5
If you have AIM-VPN/SSL-2 than YES for 2811.{The Cisco VPN and SSL AIM uses Layer 3 IPPCP compression.}
Otherwise NO
See if you would get more Idea:
http://www.cisco.com/en/US/products/ps5853/products_data_sheet0900aecd804ff58a.html
Dharmesh Purohit
Dharmesh, I made some research on IPPCP and it does hardware encryption and software compression. What i am looking for is if its possible to make hardware compression on Serial interface using the AIM-VPN/SSL module. If yes what are the commands since i have tried a few commands and it still didnt work out.
JANKEE Pankaj
