Cisco 2811 Help
rgruber
Thanks for help in advance.  I have a fiber 10mb connection delivered as Ethernet.  I have a 2811, (1) HWIC -1FE and (1) HWIC -4ESW.  I would like to know which module I should use and configuration example.  Also, my ISP gave me serials and my LAN block.  I was wondering if I even need the serials IPs.  Can I just plug in to the HWIC-1FE and use one of the IPs from the LAN block?  Do I need to worry about encapsulation?  Thanks.
Leo Laohoo
Duplicate post #1.
