05-19-2025 03:32 PM - edited 05-19-2025 03:32 PM
Hello Cisco Community,
I recently purchased a used Cisco 2811 router (PID: CISCO2811, S/N: FTX1421AHUZ) and replaced its original AC power supply with a DC power supply. However, the command show env all still shows "Main Power Supply is AC" even though only a single DC power supply is connected. The router boots up normally, and the DC power input is confirmed to be working.
Details:
IOS Version: 12.4 (17a)
Modules Installed:
PVDM2-64 (DSP SIMM)
NM-16ESW (16-port EtherSwitch)
Commands & Outputs:
Router#show inventory NAME: "2811 chassis", DESCR: "2811 chassis" PID: CISCO2811, VID: V08, SN: FTX1421AHUZ NAME: "PVDMII DSP SIMM with four DSPs", DESCR: "PVDMII DSP SIMM with four DSPs" PID: PVDM2-64, VID: V01, SN: FOC14191KZN NAME: "16 Port 10BaseT/100BaseTX EtherSwitch", DESCR: "16 Port 10BaseT/100BaseTX EtherSwitch" PID: NM-16ESW, VID: V01, SN: FOC104421SY Router#show env all Main Power Supply is AC Fan 1 OK Fan 2 OK Fan 3 OK System Temperature: 24 Celsius (normal) Environmental information last updated 00:00:05 ago
Issue Summary:
The router detects the power supply as AC despite using a DC power unit.
I suspect this is an IOS 12.4(17a) bug, but I couldn't find any official Cisco documentation or Bug ID related to this issue.
Questions:
Has anyone encountered a similar problem with Cisco 2800 series routers?
Is there a known Bug ID or Cisco document addressing this power supply detection issue?
Since this is a second-hand device, I don't have a Cisco service contract. Any guidance would be greatly appreciated!
Thank you in advance.
05-20-2025 08:41 AM
I see no relferrnce of the PSU in the inventory
Are you sure this model accepts modular power supply
05-20-2025 09:55 AM - edited 05-20-2025 09:56 AM
I've checked it's not modular, but you can/must open the chassis to replace the power module.
05-20-2025 06:21 PM
correct. for change muse open chassis
05-20-2025 06:21 PM
No, this model does not accept a modular power supply.
You have to open the cover and install the power supply internally. It is not a modular, hot-swappable type.
