Cisco 2811 Router - Need Help W/ Basic Configuration
mikewestpcs
Hello everyone, I've followed a few guides online to try and set up my router. I would like to use the two FastEthernet ports available on the 2811 for my network. I want to use one for my outside Ip address coming from the ISP and the other for my LAN to hand out Ips to the devices on my network.
With my current configuration, I still cannot connect to the internet when I plug my computer into my LAN port.
Here is my current configuration (sh running-config cmd)
Current configuration : 1565 bytes
version 12.4
hostname USCORRTRCCA01R
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
enable secret 5 $1$ZBd9$QJjb9Oi6wKrHPyAYcnsq2.
enable password chpm7612
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp pool LAN
network 192.168.15.0 255.255.255.0
default-router xx.xx.87.2
dns-server xx.x.224.17 xx.x.224.18
no ip domain lookup
voice-card 0
no dspfarm
archive
log config
hidekeys
interface FastEthernet0/0
description ***LAN***
ip address 192.168.15.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description ***INTERNET***
ip address xx.xx.87.2 255.255.255.248
ip nat outside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xx.xx.87.3
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit 0.0.0.0 255.255.255.0
access-list 1 permit 0.0.0.1 255.255.255.0
access-list 1 permit 192.168.15.0 0.0.0.255
access-list 1 permit any
control-plane
line con 0
line aux 0
line vty 0 4
access-class 1 in
password chadmin83
login
scheduler allocate 20000 1000
end
ANY HELP IS GREATLY APPRECIATED!!
P.S. I x'd out parts of my ip for privacy, incase you were wondering
15 Replies 15
mikewestpcs
BUMP.....
