Cisco 2811 router not booting properly
jegan1234
I am using a cisco 2811 router.It is not booting properly.It reboots continously by just decompressing the image repeatedly....Can someone help me in this issue....
Reza Sharifi
Have you upgraded the IOS lately?  Some times this happens, because you have loaded the wrong IOS on the device or the image was corrupted during download.
If this is not the case, then you can boot the router to Rommon and try to add the boot variable for your IOS and boot it.  If not, then you may have to download a new IOS and use Xmodem to loaded.
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_image.html#wp1063658
Reza
Ganesh Hariharan
As Reza said it can happen with wrong IOS been copied,check out the below link for recovering the ios
http://www.freeccnaworkbook.com/labs/section-2-basic-cisco-router-and-switch-management/lab-2-11-recovering-a-corrupt-cisco-ios-image-on-a-2600-series-router/
Hope to Help !!
Ganesh.H
