Cisco 2811 Router - Setup second external IP or not
anthonywald
I have a 2811 that is setup with an external IP, this has access lists and firewalling turned on. I need to setup OWA (SSL) through it to point to an internal server. I am wondering whether it is best to setup a second external IP or not necessary.
The internal server is at 192.xxx.xxx.100
The secondary external IP if needed is xxx.xxx.xxx.131
The existing config for the external port is:
interface FastEthernet0/0
description To ISP-INTERNET
ip address xxx.xxx.xxx.130 255.255.255.248
ip access-group 120 in
ip nat outside
ip inspect FIREWALL out
ip virtual-reassembly
duplex auto
speed auto
crypto map To-HQ
interface FastEthernet0/0.101
a.alekseev
Level 7
Level 7
you needn't use a secondary ip for this.
Just do static NAT or static PAT.
ip nat inside source static 192.xxx.xxx.100 xxx.xxx.xxx.131
ip nat inside source static tcp 192.xxx.xxx.100 443 xxx.xxx.xxx.131 443
