02-08-2017 07:04 AM - edited 03-05-2019 08:00 AM
I have a Cisco 2821 with 3 wic, 2 wic adsl and 1 wic eth. I need to configure the two adsl wics in load balancing and failover and in case of all the two adsl don't work, all the traffic must be routed on the eth wic wan.
The IOS version is 12.4
Can You help me?
Salve,
ho un router Cisco 2821 con 3 interfacce wic, di cui due adsl e una wan. Avrei la necessità di far lavorare le due wic adsl in load balancing e fail over e, in caso nessuna delle due linee funzioni, il traffico esca sulla wan eth.
C'è qualcuno che mi può dare la configurazione?
La versione dell'os è la 12.4.
Grazie
Solved! Go to Solution.
03-09-2017 12:32 PM
what caused the system to crash ? Did you do anything specific ? Post the output of 'show version', looks like you are either facing a hardware or a software induced crash.
03-09-2017 12:51 PM
06-02-2017 09:54 AM
The config Working but one server (Win srv 2012) on the lan have problem to download files from a FTP server, and other PCs work with ftp
Can You help me?
