Cisco 2821 Router
saroj pradhan
can some one provide me  urgent support .
i have  cisco 2821 router  in my  network  and for the requiremet i have  installed  one  dual port HWIC-2FE  card .
in the show int and  sh ip int br   command  it is  not showing the newly  installed  FE but  in the sh diag  the following  showing.
My Router has the version details below.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(11)XW9, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sat 09-Aug-08 16:51 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
        WIC Slot 2:
        2 Port FE HWIC
        WIC module not supported/disabled in this slot
        Hardware Revision        : 2.0
        Top Assy. Part Number    : 800-33018-01
        Part Number              : 73-12949-01
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        PCB Serial Number        : FOC15372RF7
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : HWIC-2FE
        Version Identifier       : V02
        CLEI Code                : COUIAFUCAB
        Base MAC Address         : 7081.0575.845f
        MAC Address block size   : 2
        Connector Type           : 01
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 05 3B 41 02 00 C0 46 03 20 00 80 FA 01
          0x10: 82 49 32 95 01 42 41 30 88 00 00 00 00 02 03 C1
          0x20: 8B 46 4F 43 31 35 33 37 32 52 46 37 03 00 81 00
          0x30: 00 00 00 04 00 CB 92 48 57 49 43 2D 32 46 45 20
          0x40: 20 20 20 20 20 20 20 20 20 89 56 30 32 20 D9 02
          0x50: 40 C1 C6 8A 43 4F 55 49 41 46 55 43 41 42 CF 06
          0x60: 70 81 05 75 84 5F 43 00 02 05 01 FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
please advice to bring the interface  UP.
Saroj
16 Replies 16
Mahesh Gohil
Level 7
Level 7
sh diag output showing below error.
WIC module not supported/disabled in this slot.
So if it is supported on this platform kindly insert in another slot and check.
Regards # Mahesh
I have installed on another slot found same problem.
Can you please advice the Interface Module supported by cisco 2821 Router.
Saroj
Leo Laohoo
You've got the wrong IOS.  You need an IOS with the "T" train.
if i upgrade the IOS  of T will the interface  work ?
If you upgrade to an IOS with the "T" train, your interface will be detected by the router.
Can you please provide me the Exat ios ver.
Go to the Cisco Download site and look under the 12.4T category.  Choose the IOS of your choice from this category.
OK Thanks….
Will it work for me ?
Release
12.4.24T6
Filename
c2800nm-adventerprisek9-mz.124-24.T6.bin
Product Code
S28NUAESK9-12424T
Release Date
31/Aug/2011
Minimum Memory
DRAM:256 MB Flash:128 MB
Size
58067.5859375 KB (59461208 bytes)
Router Checksum
0x2821
MD5
5ab04724ee2b6230872352f14e719f96
Additional Information
Security Advisories
Security Advisories
Field Notices
Field Notices
Yes it will, just make sure you have DRAM:256 MB  Flash:128 MB on board and you can go ahead.
BR,
Jacek
Thanks for the support I will use another IOS as my Router has 64 mb.
The IOS I Will use ---c2800nm-advsecurityk9-mz.124-24.T6.bin which is 36MB.
But my Router has free space only 5775360 bytes available so how to upgrade ?
simply type "yes" when you see prompt:
"Erase flash: before copying? [confirm]" y
It will erase flash and make space for new IOS.
http://www.cisco.com/en/US/products/ps5855/products_tech_note09186a00801fc986.shtml#example1
BR,
Jacek
I don’t get the option Erase Flash :before Copying .
Get the Error : %Error copying ftp://****:****@122.168.191.87/c2800nm-advsecurityk9-mz.124-24.T6.bin (Not enough space on device)
Please advice other options…..
The other option is to manually delete the existing image from flash and then copy the new image into flash.
I have done this many times and it works. Note that there is a potential problem with doing this - if the router were to reload for some reason after you have manually deleted the existing image and before the download of the new image has completed then the router will not have an image to boot. This is not likely but you do need to be aware of the possibility in deciding whether you want to use this option.
Rick
Rick
