cisco 2851 wan setup help
CrazyxRascal
hi guys i just brought a cisco 2851 and i wonder if someone could help me config the wan ? but am not having any luck. I'm new to the Cisco world. if someone could add me on skype joshhopey i could show you what parts i am having issues with my skype is joshhopey
Ok. To configure your wan interface as pppoe and negotiated address, let's assume your wan interface is g0/1.
configuration:
interface GigabitEthernet 0/0/0
 no ip address
 pppoe enable
 pppoe-client dial-pool-number 1
interface dialer 1
 mtu 1492
 ip address negotiated
 encapsulation ppp
 dialer pool 1
 ppp pap sent-username bthomehub@btbroadband.com password bt
If the authentication is chap/pap, you need to add those commands on dialer 1 interface:
ppp authentication pap chap callin
ppp chap hostname bthomehub@btbroadband.com
ppp chap password bt
hope this will help. Let me know.
Please don't forget to rate and select it as correct answer if this is solving your issue.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
6 Replies 6
Francesco Molino
Could you explain where are you facing issues? Is it for NAT?
What is connected to your WAN interface? Modem, router,... ?
I can help but I need more information.
Francesco
hi mate i am just having issues setting up the wan , it going from modem to the cisco router . have you got skype ? or anything so i can show you on team viewer and be able to help me ?
skype joshhopey
no I don't have skype right now.
Explain more in details and I will try to help this evening or tomorrow. In order to help, give a quick drawing and some details of what you want to achieve.
thanks
Francesco
i am struggling to setup the cisco router . i need the wan for pppe bthomehub@btbroadband.com pass bt . then i need the lan setup for dhcp . i got sdm . just strugging to set up the router
configuration:
 no ip address
 pppoe enable
interface dialer 1
 mtu 1492
 encapsulation ppp
 dialer pool 1
Francesco
i going  inbox you my team viewer quickly
