Cisco 2901/K9 or 1941/K9
GAB1
Joseph W. Doherty
They are very close in performance, the reason for your question? If so, you would want to review other hardware differences, such as whether the 2901 might offer more hardware interface options than a 1941, that you need now or perhaps later.
You might also consider newer routers, such as the 1100 series.
Leo Laohoo
Depends on the WAN bandwidth.
Joseph W. Doherty
It's no clear on cisco router 2901/K9 if i can use HWIC-4T interfaces on
the slots. My question is if i can use HWIC-4T interfaces?
