12-14-2016 04:38 PM - edited 03-05-2019 07:40 AM
Can I get some help here with IPv6 configuration its not binding at all.
Shawn.
S ::/0 [1/0]
via Ethernet0/0/0, directly connected
C 2001:8000:1A43:9800::/56 [0/0]
L 2001:8000:1A43:9800:BE16:65FF:FE05:C6F8/128 [0/0]
via Ethernet0/0/0, receive
L FF00::/8 [0/0]
via Null0, receive
Building configuration...
Current configuration : 16673 bytes
version 15.5
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
ethernet lmi ce
clock timezone PCTime 10 0
no ip source-route
ip port-map user-protocol--8 port udp 3394
ip port-map user-protocol--9 port tcp 3396
ip port-map user-protocol--2 port udp 3391
ip port-map user-protocol--3 port tcp 3478
ip port-map user-protocol--1 port tcp 3391
ip port-map user-protocol--6 port udp 5062
ip port-map user-protocol--7 port tcp 3394
ip port-map user-protocol--4 port udp 3478
ip port-map user-protocol--5 port tcp 5062
ip port-map user-protocol--12 port udp 7547
ip port-map user-protocol--11 port tcp 7547
ip port-map user-protocol--10 port udp 3396
ip dhcp excluded-address 192.168.1.1 192.168.1.49
ip dhcp pool DHCP_POOL
import all
network 192.168.1.0 255.255.255.0
dns-server 139.130.4.4 203.50.2.71
default-router 192.168.1.1
no ip bootp server
ip name-server 139.130.4.4
ip name-server 203.50.2.71
ip name-server 2001:8000:101::1
ip name-server 2001:8000:101::2
ip cef
ipv6 unicast-routing
ipv6 dhcp pool NODE-DHCPV6
dns-server 2001:8000:101::1
dns-server 2001:8000:101::2
ipv6 inspect name STD6 udp
ipv6 inspect name STD6 ftp
ipv6 inspect name STD6 icmp
ipv6 cef
crypto pki trustpoint TP-self-signed-1982477479
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1982477479
revocation-check none
rsakeypair TP-self-signed-1982477479
license udi pid CISCO2901/K9 sn
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package datak9
username name privilege 15 secret 5
redundancy
controller VDSL 0/0/0
operating mode vdsl2
firmware filename flash:VA_A_39t_B_35j_24m.bin
sra
no cdp run
ip tcp synwait-time 10
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
class-map type inspect match-all sdm-nat-user-protocol--7-1
match access-group 103
match protocol user-protocol--7
class-map type inspect match-all sdm-nat-user-protocol--4-2
match access-group 105
match protocol user-protocol--4
class-map type inspect match-all sdm-nat-user-protocol--6-1
match access-group 102
match protocol user-protocol--6
class-map type inspect match-all sdm-nat-user-protocol--5-1
match protocol user-protocol--5
class-map type inspect match-all sdm-nat-user-protocol--4-1
class-map type inspect match-all sdm-nat-user-protocol--7-2
match access-group 104
class-map type inspect match-all sdm-nat-user-protocol--3-1
match protocol user-protocol--3
class-map type inspect match-all sdm-nat-user-protocol--2-1
match access-group 101
match protocol user-protocol--2
class-map type inspect match-all sdm-nat-user-protocol--1-1
match protocol user-protocol--1
class-map type inspect match-all sdm-nat-user-protocol--3-2
class-map type inspect match-all sdm-nat-user-protocol--8-2
match protocol user-protocol--8
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-all sdm-nat-user-protocol--9-1
match protocol user-protocol--9
class-map type inspect match-all sdm-nat-user-protocol--8-1
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-all sdm-nat-sip-tls-1
match protocol sip-tls
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all sdm-nat-sip-tls-2
class-map type inspect match-all sdm-nat-user-protocol--12-1
match protocol user-protocol--12
class-map type inspect match-all sdm-nat-user-protocol--11-2
match protocol user-protocol--11
class-map type inspect match-all sdm-nat-user-protocol--10-1
match protocol user-protocol--10
class-map type inspect match-all sdm-nat-user-protocol--11-1
class-map type inspect match-all sdm-nat-user-protocol--12-2
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-cls-insp-traffic
match protocol pptp
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all SDM_GRE
match access-group name SDM_GRE
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all sdm-nat-sip-2
match protocol sip
class-map type inspect match-all sdm-nat-sip-1
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
class-map type inspect match-any SDM_DHCP_CLIENT_PT
match class-map SDM_BOOTPC
class-map type inspect match-any CCP_PPTP
match class-map SDM_GRE
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
drop log
class type inspect ccp-protocol-http
inspect
class type inspect ccp-insp-traffic
inspect
class type inspect ccp-sip-inspect
inspect
class type inspect ccp-h323-inspect
inspect
class type inspect ccp-h323annexe-inspect
inspect
class type inspect ccp-h225ras-inspect
inspect
class type inspect ccp-h323nxg-inspect
inspect
class type inspect ccp-skinny-inspect
inspect
class class-default
drop
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-nat-user-protocol--1-1
inspect
class type inspect sdm-nat-user-protocol--2-1
inspect
class type inspect CCP_PPTP
pass
class type inspect sdm-nat-sip-1
inspect
class type inspect sdm-nat-user-protocol--3-1
inspect
class type inspect sdm-nat-user-protocol--4-1
inspect
class type inspect sdm-nat-sip-tls-1
inspect
class type inspect sdm-nat-user-protocol--5-1
inspect
class type inspect sdm-nat-user-protocol--6-1
inspect
class type inspect sdm-nat-user-protocol--7-1
inspect
class type inspect sdm-nat-user-protocol--8-1
inspect
class type inspect sdm-nat-user-protocol--7-2
inspect
class type inspect sdm-nat-user-protocol--8-2
inspect
class type inspect sdm-nat-user-protocol--9-1
inspect
class type inspect sdm-nat-user-protocol--10-1
inspect
class type inspect sdm-nat-user-protocol--11-1
inspect
class type inspect sdm-nat-user-protocol--12-1
inspect
class type inspect sdm-nat-sip-2
inspect
class type inspect sdm-nat-user-protocol--3-2
inspect
class type inspect sdm-nat-user-protocol--4-2
inspect
class type inspect sdm-nat-user-protocol--11-2
inspect
class type inspect sdm-nat-user-protocol--12-2
inspect
class type inspect sdm-nat-sip-tls-2
inspect
class class-default
drop log
policy-map type inspect ccp-permit
class type inspect SDM_DHCP_CLIENT_PT
pass
class class-default
drop
policy-map type inspect ccp-permit-icmpreply
class type inspect sdm-cls-bootps
pass
class type inspect ccp-icmp-access
inspect
class class-default
pass
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
interface Null0
no ip unreachables
interface Embedded-Service-Engine0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly in
zone-member security in-zone
duplex auto
speed auto
ipv6 address NODE-PD ::1/64
ipv6 enable
ipv6 nd other-config-flag
ipv6 dhcp server NODE-DHCPV6 rapid-commit
ipv6 verify unicast reverse-path
ipv6 inspect STD6 out
ipv6 traffic-filter DENY-ACL6 out
no mop enabled
interface GigabitEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
duplex auto
speed auto
no mop enabled
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
no atm ilmi-keepalive
interface Ethernet0/0/0
description $FW_OUTSIDE$$ETH-WAN$
ip address dhcp client-id Ethernet0/0/0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
zone-member security out-zone
ipv6 address 2001:8000:1A43:9800::/56 eui-64
ipv6 address NODE-PD ::FF:0:0:0:1/128
ipv6 enable
ipv6 dhcp client pd NODE-PD rapid-commit
ipv6 traffic-filter INTERNET-IN-ACL6 in
no mop enabled
interface GigabitEthernet0/3/0
no ip address
interface GigabitEthernet0/3/1
no ip address
interface GigabitEthernet0/3/2
no ip address
interface GigabitEthernet0/3/3
no ip address
interface GigabitEthernet0/3/4
no ip address
interface GigabitEthernet0/3/5
no ip address
interface GigabitEthernet0/3/6
no ip address
interface GigabitEthernet0/3/7
no ip address
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip forward-protocol nd
ip http server
ip http access-class 3
ip http authentication local
ip http secure-server
no ip ftp passive
ip nat portmap VOICE
cisco-rtp-sip-low
cisco-rtp-skinny-low
ip nat inside source list 1 interface Ethernet0/0/0 overload
ip nat inside source static tcp 192.168.1.35 3391 interface Ethernet0/0/0 3391
ip nat inside source static udp 192.168.1.35 3391 interface Ethernet0/0/0 3391
ip nat inside source static tcp 192.168.1.29 5060 interface Ethernet0/0/0 5060
ip nat inside source static udp 192.168.1.29 5060 interface Ethernet0/0/0 5060
ip nat inside source static tcp 192.168.1.29 3478 interface Ethernet0/0/0 3478
ip nat inside source static udp 192.168.1.29 3478 interface Ethernet0/0/0 3478
ip nat inside source list 110 interface Ethernet0/0/0 overload portmap VOICE
ip nat inside source static tcp 192.168.1.5 3394 interface Ethernet0/0/0 3394
ip nat inside source static udp 192.168.1.5 3394 interface Ethernet0/0/0 3394
ip nat inside source static tcp 192.168.1.10 3396 interface Ethernet0/0/0 3396
ip nat inside source static udp 192.168.1.10 3396 interface Ethernet0/0/0 3396
ip nat inside source static tcp 192.168.1.29 7547 interface Ethernet0/0/0 7547
ip nat inside source static udp 192.168.1.29 7547 interface Ethernet0/0/0 7547
ip nat inside source static tcp 192.168.1.29 5061 interface Ethernet0/0/0 5061
ip nat inside source static udp 192.168.1.29 5061 interface Ethernet0/0/0 5061
ip route 0.0.0.0 0.0.0.0 dhcp
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
ip access-list extended SDM_GRE
remark CCP_ACL Category=1
permit gre any any
logging trap debugging
ipv6 route ::/0 Ethernet0/0/0
access-list 1 remark INSIDE_IF=lan
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 remark HTTP Access-class list
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 2 deny any
access-list 3 remark HTTP Access-class list
access-list 3 remark CCP_ACL Category=1
access-list 3 permit 192.168.1.0 0.0.0.255
access-list 3 deny any
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=0
access-list 101 permit ip any host 192.168.1.35
access-list 102 remark CCP_ACL Category=0
access-list 102 permit ip any any
access-list 103 remark CCP_ACL Category=0
access-list 103 permit ip any host 192.168.1.10
access-list 104 remark CCP_ACL Category=0
access-list 104 permit ip any host 192.168.1.5
access-list 105 remark CCP_ACL Category=0
access-list 105 permit ip any host 192.168.1.29
access-list 110 permit udp any any range 16384 16482
access-list 110 permit tcp any any range 16384 16482
access-list 110 permit udp any any range 35000 45000
access-list 110 permit tcp any any range 35000 45000
access-list 111 permit tcp any any eq 7547
ipv6 access-list DENY-ACL6
permit icmp any any
permit tcp any any established
deny ipv6 any any
ipv6 access-list INTERNET-IN-ACL6
permit icmp any any
permit udp any any eq 546
deny ipv6 any any
control-plane
banner login ^CE-Rescue Systems^C
line con 0
transport output telnet
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login authentication local_authen
transport input telnet ssh
line vty 5 15
scheduler allocate 20000 1000
event manager applet MONITOR-IPV6-DHCP-APP
event syslog pattern "ETHERNET-BIND"
action 1.0 cli command "enable"
action 1.1 cli command "clear ipv6 dhcp client ethernet 0/0/0"
action 2.0 syslog priority debugging msg "Refreshed IPv6 DHCP PD lease"
end
04-17-2017 04:14 PM
Moving this to the correct community: Network Infrastructure>WAN
