Cisco 2901C2901 15.4(3)M3 Netflow configuration not working
vasil.georgiev
Hi All,
I am trying to implement Flexible NetFlow on 2901C2901 15.4(3)M3
flows were not getting exported from the device.
I tried checking this with Wireshark and no netflow traffic was seen.
Please let me know if you can think of anything.
show run
Building configuration...
Current configuration : 7380 bytes
version 15.4
hostname RTR-TEST
boot-start-marker
boot-end-marker
logging buffered 4096
no logging console
aaa new-model
aaa authentication login default local
aaa authorization console
aaa authorization exec default local
aaa session-id common
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause rootguard
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery interval 600
ip flow-cache timeout active 1
no ip domain lookup
ip domain name ############(hiding this)
ip multicast-routing
ip multicast heartbeat 239.3.21.51 1 10 10
ip multicast heartbeat 239.8.11.81 1 1 10
ip cef
no ipv6 cef
flow exporter FNDexp
destination 10.25.17.5
source GigabitEthernet0/1.15
transport udp 9996
flow record FNFREC
match routing is-multicast
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
collect routing forwarding-status
collect routing multicast replication-factor
collect ipv4 dscp
collect ipv4 ttl
collect ipv4 source mask
collect ipv4 destination mask
collect interface input
collect interface output
collect counter bytes
collect counter packets
collect counter bytes replicated
collect counter packets replicated
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow monitor FNFMON
exporter FNDexp
record FNFREC
cts logging verbose
crypto pki trustpoint TP-self-signed-1629017464
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1629017464
revocation-check none
rsakeypair TP-self-signed-1629017464
crypto pki certificate chain TP-self-signed-1629017464
voice-card 0
license udi pid CISCO2901/K9 sn ############(hiding this)
hw-module pvdm 0/0
vtp domain ############(hiding this)
vtp mode transparent
vtp version 2
username ############(hiding this) privilege 15 ############(hiding this)
username ############(hiding this) privilege 15 secret ############(hiding this)
redundancy
ip ssh rsa keypair-name KEYPAIR
ip ssh version 2
class-map type multicast-flows mc-vlan1
class-map type multicast-flows mc-vlan10
group 239.3.111.1
class-map type multicast-flows mc-vlan17
group 239.8.11.1
group 239.3.106.1
group 239.3.105.1
group 239.3.104.1
group 239.3.103.1
group 239.3.102.1
group 239.3.101.1
group 239.3.26.51
group 239.3.25.51
group 239.3.24.51
group 239.3.23.51
group 239.3.21.51
group 239.3.21.52
group 239.3.20.51
group 239.3.20.52
group 239.3.1.1
group 239.3.0.1
group 239.8.11.81
group 225.8.11.81
group 239.3.10.1
group 239.3.10.2
group 239.3.10.3
group 239.3.10.4
group 239.3.10.5
group 239.3.21.1
group 239.3.0.21
group 239.3.99.52
group 239.3.111.1
group 239.3.17.19
group 239.3.99.54
group 239.3.20.53
group 239.3.17.20
class-map type multicast-flows mc-vlan11
group 239.3.102.1
group 239.3.1.1
group 239.3.0.1
group 239.3.112.1
class-map type multicast-flows mc-vlan13
group 239.3.102.1
group 239.3.1.1
group 239.3.0.1
group 239.3.113.1
class-map type multicast-flows mc-vlan14
group 239.3.105.1
group 239.3.1.1
group 239.3.0.1
group 239.3.115.1
class-map type multicast-flows mc-vlan15
group 239.3.106.1
group 239.3.1.1
group 239.3.0.1
class-map type multicast-flows mc-vlan20
group 239.3.26.51
group 239.3.25.51
group 239.3.24.51
group 239.3.23.51
group 239.3.21.51
group 239.3.21.52
group 239.3.20.51
group 239.3.20.52
group 239.3.20.53
class-map type multicast-flows mc-vlan21
group 239.3.21.51
group 239.3.21.52
class-map type multicast-flows mc-vlan23
group 239.3.23.51
class-map type multicast-flows mc-vlan24
group 239.3.24.51
class-map type multicast-flows mc-vlan25
group 239.3.25.51
class-map type multicast-flows mc-vlan30
group 239.8.11.1
group 239.8.11.81
group 225.8.11.81
class-map type multicast-flows mc-vlan33
group 239.8.11.1
group 239.8.11.81
group 225.8.11.81
bridge irb
interface Loopback0
ip address 10.25.255.254 255.255.255.255
ip pim sparse-mode
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
ip flow monitor FNFMON input
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
ip flow ingress
duplex auto
speed auto
interface GigabitEthernet0/1.12
encapsulation dot1Q 12
ip flow ingress
bridge-group 12
interface GigabitEthernet0/1.15
encapsulation dot1Q 15
ip unnumbered BVI15
bridge-group 15
interface GigabitEthernet0/1.17
encapsulation dot1Q 17
ip unnumbered BVI17
bridge-group 17
interface GigabitEthernet0/1.18
encapsulation dot1Q 18
ip unnumbered BVI18
bridge-group 18
interface GigabitEthernet0/1.19
interface GigabitEthernet0/1.20
description Gig-01.20-VLAN20
encapsulation dot1Q 20
bridge-group 20
interface GigabitEthernet0/1.25
description Gig-01.25-VLAN25
encapsulation dot1Q 99
bridge-group 99
interface BVI15
ip address 10.25.15.241 255.255.255.0
ip pim sparse-mode
standby version 2
standby 15 ip 10.25.15.254
standby 15 timers 15 255
standby 15 priority 110
standby 15 preempt
standby 15 name hsrp15
ip igmp static-group class-map mc-vlan17
interface BVI17
ip address 10.25.17.241 255.255.255.0
ip pim sparse-mode
standby version 2
standby 17 ip 10.25.17.254
standby 17 timers 15 30
standby 17 priority 110
standby 17 preempt
standby 17 name hsrp17
interface BVI18
ip address 10.25.18.241 255.255.255.0
ip pim sparse-mode
standby version 2
standby 18 ip 10.25.18.254
standby 18 timers 15 255
standby 18 priority 110
standby 18 preempt
standby 18 name hsrp18
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-export source GigabitEthernet0/1.15
ip flow-export version 9
ip flow-export template timeout-rate 1
ip flow-export destination 10.25.17.5 9996
ip pim rp-candidate Loopback0 priority 5
ip route 10.25.255.251 255.255.255.255 10.25.18.240
ip route 10.25.255.253 255.255.255.255 10.25.18.243
logging trap critical
snmp-server community ############(hiding this)
snmp-server ifindex persist
control-plane
bridge 14 protocol ieee
bridge 15 protocol ieee
bridge 15 route ip
bridge 17 protocol ieee
bridge 17 route ip
bridge 18 protocol ieee
bridge 18 route ip
bridge 100 protocol ieee
bridge 171 protocol ieee
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 520 0
transport input ssh
scheduler allocate 20000 1000
end
0 Replies 0
