L2vpn Pseudowire Troubleshooting
TrivialPants
Hi All,
I am troubleshooting an issue with a 920/903 load balancing pseudowires/xconnects. I heard/read that I could use the FAT pseudowire method, but I have to transition my pseudowires from the service instance/xconnects to be defined in the l2vpn section of my config.
Here is an example:
l2vpn xconnect context TestPW
 member pseudowire1
 member GigabitEthernet0/0/1 service-instance 1
and the two members of the l2vpn context:
interface pseudowire1
 description Test FAT MPLS Load Balancing
 encapsulation mpls
 neighbor 10.0.0.1 123
 mtu 1998
end
interface GigabitEthernet0/0/1
 description test
 mtu 1998
 no ip address
 negotiation auto
 no keepalive
 service instance 1 ethernet
  description Test FAT PW Load Balance
  encapsulation untagged
The pseudowire/l2vpn is established with the neighbor which has the same mtu size on the other end and vc IDs match, but I am unable to ping across. I just have a test laptop on either end (with firewalls disabled for testing) and am pinging across 192.168.2.1 on one side to 192.168.2.2 to the other side, but the traffic is not seeming to make it across.
Any ideas? Anything that is obviously missing from the config?
follow
