Cisco 2911 NAT from VRF
ruth_betty
I have a trouble with NAT connection on Cisco 2911 ISR. I cannot connect to the NAT port from PC on same VRF. But it connection work properly if I try do it from another VRF on same router. Can you help me fix it?
Spoiler
version 15.2
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname bgr-03
boot-start-marker
boot-end-marker
logging buffered 51200
logging rate-limit all 10 except critical
logging monitor informational
aaa new-model
aaa authentication login local_auth local
aaa session-id common
clock timezone MSK 3 0
ip cef
ip vrf VRF20
ip vrf VRF30
no ip domain lookup
ipv6 spd queue min-threshold 62
ipv6 spd queue max-threshold 63
no ipv6 cef
voice-card 0
license udi pid CISCO2911/K9 sn FFFFFFFFFFF
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
license boot module c2900 technology-package datak9
vtp mode transparent
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.20
 encapsulation dot1Q 20
 ip vrf forwarding VRF20
 ip address 10.0.20.1 255.255.255.0
 no ip redirects
 ip nat inside
 ip virtual-reassembly in
interface GigabitEthernet0/0.30
 encapsulation dot1Q 30
 ip vrf forwarding VRF30
 ip address 10.0.30.1 255.255.255.0
 no ip redirects
 ip nat inside
interface GigabitEthernet0/1
 ip address 1.1.1.2 255.255.255.0
 no ip redirects
 ip nat outside
 load-interval 30
 duplex auto
 speed auto
 no cdp enable
interface GigabitEthernet0/2
 ip address 1.1.1.3 255.255.255.0
 no ip redirects
 ip nat outside
 load-interval 30
 duplex auto
 speed auto
 no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat translation timeout 7200
ip nat translation tcp-timeout 7200
ip nat inside source list NAT_VRF20 interface GigabitEthernet0/1 vrf VRF20 overload
ip nat inside source list NAT_VRF30 interface GigabitEthernet0/2 vrf VRF30 overload
ip nat inside source static tcp 10.0.20.2 3389 1.1.1.2 3389 vrf VRF20 extendable
ip nat inside source static tcp 10.0.30.2 3389 1.1.1.3 3389 vrf VRF30 extendable
ip route vrf VRF20 0.0.0.0 0.0.0.0 1.1.1.1
ip route vrf VRF30 0.0.0.0 0.0.0.0 1.1.1.1
ip access-list extended NAT_VRF20
 deny   ip any 10.0.0.0 0.255.255.255
 deny   ip any 172.16.0.0 0.15.255.255
 deny   ip any 192.168.0.0 0.0.255.255
 permit ip 10.0.20.0 0.0.0.255 any
ip access-list extended NAT_VRF30
 permit ip 10.0.30.0 0.0.0.255 any
control-plane
mgcp profile default
gatekeeper
 shutdown
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 transport input none
scheduler allocate 20000 1000
end
9 Replies 9
Julio E. Moisa
Could you please share the configuration? it should be something like:
ip nat inside source list 1 interface G0/0 vrf <VRF NAME> overload
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Of cource, its under spoiler in my first post ;)
Thank you, apologies I didn't see it. I recommend configure Route-distinguisher on the VRF, for example:
ip vrf VRF20
rd 20:20
ip vrf VRF20
rd 30:30
The values can be random, please let me take a look to the entire configuration.
Also the deny into the ACL could be removed because the ACL will include the allowed networks only:
And the ACL will apply the implicit deny ip any any at the bottom.
This lines added because I want exclude NAT for packets with destination to gray networks (10*, 192*, 172*, etc.). Yes, I agree I must do it in another way, with "ip route" to Null interface, but in our case this does not matter and you can simply remove this lines.
> rd 20:20
> rd 30:30
I add Route-distinguisher on VRFs, but it didn't help.
Its entire configuration without cut. This is so small because I made special stand for diagnose this problem.
ruth_betty
Really nobody meet such problem? How can I try to solve it?
Apologies for the late response, have you tried to leak using the global routing. Also i would like to know if you have control the neighbor connected to the routeer into the topology or is it already the ISP?
Can you describe please, how can I do it?
In production its a border router, interfaces Gi0/1 and Gi0/2 connected to the ISP. But for resolve this issue I made clear stand and can connect to this interfaces any devices.
