SIP calls does not end
mateus.schott
there is a way to terminate the SIP calls, it happens that calls get stuck and I need to restart the router to be able to remove the connections.
#show call active voice compact
<callID>  A/O FAX T<sec> Codec       type        Peer Address       IP R<ip>:<udp>
Total call-legs: 10
      2661 ANS     T2895 g711alaw    VOIP        P855362    172.16.15.108:26972
      2662 ORG     T2895 g711alaw    VOIP        P988449290   10.182.202.138:51430
      3074 ANS     T623   g711alaw    VOIP        P855323    172.16.15.119:23848
      3075 ORG     T623   g711alaw    TELE        P0996627041
      3165 ANS     T107   g711alaw    VOIP        P855357    172.16.15.109:31542
      3166 ORG     T107   g711alaw    VOIP        P025888100   172.31.103.101:36508
      3171 ANS     T0     g711alaw    VOIP        P855368    172.16.15.110:30856
      3172 ORG     T0     g711alaw    VOIP        P0219821089897    189.52.92.157:41124
      3186 ANS     T0     g711alaw    VOIP        P855349    172.16.15.113:22072
      3187 ORG     T0     None        TELE        P0997885470
shawngennuso
Level 4
Level 4
Use the clear call voice command:
VG1#clear call voice causecode ?
<1-127>  Q.850 disconnect cause code numbers
VG1#clear call voice causecode 1 ?
called-number   clear only call with specific called number pattern
calling-number  clear only call with specific calling number pattern
fpi-correlator  clear call based on VoIP FPI correlator
fpi-stale       clear all hung fpi call
id              clear only call with specific id
long-dur-call   clear only call with long-duration being detected
media-inactive  clear only call with media inactive being detected
VG1#clear call voice causecode 1 id 123
keglass
Level 7
Level 7
Mateus,
I recommend you post this to the Cisco Support Community for more information and trouble shooting help specific to your particular issue.
Cisco Support Community - Cisco Support Community
Kelli Glass
Moderator for Cisco Customer Communities
shawngennuso
Level 4
Level 4
mateus.schott
Tks shawngennuso!!
