cisco 2911 no internet behind router
Ralf110666
Hello, good morning.
i have problems to get access to the internet behind an 2911. Config should be as follows.
internet is provided by an external dhcp server. signal comes through ge 0/1/0. The 2911 should be standard gateway and dhcp server for the connected clients on ge 0/0 (will be a switch later). ge 0/2/0 should be backup for ge 0/1/0 and cellular 0/0/0 should be backup for ge 0/2/0. But at the moment i am not able to get internett on a connected client at ge0/0.
I figured out the following:
2911 dhcp server is giving ip addresses through ge 0/0 as it should be ( nw 10.0.130.0 excluded 10.0.130.1-30) so i get the first ip 10.0.130.31 at a connected client.
2911 gets an ip from external dhcp on ge 0/0/0
ping is working via console on the 2911 (8.8.8.8)
ping is also translating adresses via console (www.google.com, www.cicso.com)
on a connected client at ge 0/0 i can ping the cisco2911 (static ip 10.0.130.254)
but i can not ping anything from the internet. Network connection shows no internet at windows10
actual config:
! Last configuration change at 16:06:00 UTC Sun Apr 29 2018 by admin
version 15.4
hostname cisco2911
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
--More--  !
no ip dhcp conflict logging
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.0.130.1 10.0.130.30
ip dhcp pool k130
import all
network 10.0.130.0 255.255.255.0
dns-server 8.8.4.4
default-router 10.0.130.254
ip domain name LUDWIGSHAFEN
ip name-server 10.0.130.254
ip cef
no ipv6 cef
--More--  multilink bundle-name authenticated
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
cts logging verbose
redundancy
controller Cellular 0/0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
--More--  !
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.0.130.254 255.0.0.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
--More--   no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1/0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/2/0
backup interface GigabitEthernet0/1/0
ip address dhcp
duplex auto
speed auto
interface Cellular0/0/0
no ip address
encapsulation slip
dialer in-band
dialer string lte
--More--  !
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat source list 1 interface GigabitEthernet0/1/0 overload
ip route 0.0.0.0 0.0.0.0 dhcp
access-list 1 permit 10.0.130.0 0.0.0.255
control-plane
31 Replies 31
forget about the backup for now, and try to get the Internet connectivity right first. The below is a stripped down version that should get all your local clients connected to the Internet:
ervice timestamps debug datetime msec
hostname cisco2911
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 10.0.130.254
ip dhcp pool k130
import all
dns-server 8.8.4.4
ip cef
no ipv6 cef
cts logging verbose
redundancy
no ip address
shutdown
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip http server
ip nat inside source list 1 interface GigabitEthernet0/1/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1/0 dhcp
dialer-list 1 protocol ip permit
control-plane
Hello
Suggest you remove all the resiliency config and start from scratch focusing on your primary connection first, Then when that is up and your clients can reach the internet move on to apply the resiliency otherwise you will get mixed up in what you’re doing.
The basic configuration should read the following:
ip dhcp pool k130
import all
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1/0 dhcp 1
Description LAN
 ip address 10.0.130.254 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
Description Primary WAN
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
Description Secondary WAN
SHUTDOWN
 ip address dhcp
 duplex auto
 speed auto
Then if you attaching a pc straight to the rtr , Use a cross over cable and make sure the pc receives an Ip address from your router  and see if you can ping the internet from that pc again.
res
Paul
Kind Regards
Paul
omfg... do i have to use a crossover cable if i connect a pc directly on ge 0/0?
No, straight Ethernet cable is ok. I don't think the connection to the router is a problem, you are getting a DHCP address.
Hello
Most cases nowadays gigabitethernet comes with mdix ports so no need for crossovers but if your troubleshooting connectivity making sure you have the physical level sorted first would help immensely.
So if you don have mdix ports then direct pc-router connection would require such cabling, Just get the basics working first then concentrate on the other levels after that.
From the pc you should be able receive address allocation from the rtrs dhcp scope and then be able to ping the rtrs lan interface ip address and also its dhcp assigned wan interface ip.
If you can then the next step would be to look at your network translation.
res
Paul
Kind Regards
Paul
Good morning,
unfortunately i was busy on an other project the last few days. Now i have tried the last config from geog form tuesday... not really successful, but i little step forward.
I tried out a few pings from the connected client computer.
i can reach gigabit 0/0 via ip ping
i can also reach gigabit 0/1/0 via ip ping
but i cant reach my internet access router wich is a fritz-box.
so my fritzbox gives a ip adress via dhcp to interface gigabitethernet 0/1/0 wich is actual 192.168.178.33 i can ping it from inside network address 10.0.130.31.
i can not ping the fritzbox itsself wich has ip 192.168.178.1 . From the Cisco 2911 i can ping it via console connection .... its really confusing.... maybe i should bring the 2911 back to factory defaults... but how? and what happens with user name and pw if i do?
greetings from Germany
ralf
Hello Ralf,
a little bit of progress is better than none I guess...
Post the configuration again you have right now, so we can double check...
here the actual config:
if i set ip name-server to 10.0.130.254 i get a Warnung that ip name-server is the router. I didnt do any changes to the cellular interface because i thought its maybe better to focus ge 0/1/0 to get at least one wan interface running .
i allways delete the crypto and pw phrases from my config posts. is that ok?
Current configuration : 6060 bytes
! Last configuration change at 06:29:52 UTC Sat May 5 2018 by admin
version 15.4
hostname cisco2911
boot-start-marker
boot-end-marker
no aaa new-model
--More--  !
ip dhcp pool k130
import all
dns-server 8.8.4.4
ip cef
--More--  no ipv6 cef
cts logging verbose
redundancy
--More--   lte modem link-recovery wait-timer 10
no ip address
shutdown
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
--More--   speed auto
no ip address
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
ip address dhcp
duplex auto
speed auto
no ip address
--More--   encapsulation slip
dialer in-band
dialer string lte
ip http server
control-plane
you are missing the 'inside' keyword in your NAT statement:
Delete:
and add:
YES YES YES :D
config is working .... got the client connected got Webbrowser working .... gosh great...thank you so much georg.
btw. this post is being upload through the 2911
Ralf,
good stuff, glad that you got it working in the end !
Schönes Wochenende !
The router is running after installation on place. Now i have to get the cellular 0/0/0 online. Will this work in the same manner than the GE interface, if i add the cellular 0/0/0 configuration posted in config file above?
I tried this but i think there is something missing. i get the cellular interface run ans the sim card is accepted also the pin is disabled. but i have no idea how i can input the apn, username and password to the cellular interface. i tried it with a profile but  show cellular 0/0/0 all shows the profile still inactive.
cisco2911#show cellular 0/0/0 network
Current System Time = Tue May 8 11:27:59 2018
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Network = MEDIONmobile
Mobile Country Code (MCC) = 262
Mobile Network Code (MNC) = 3
Packet switch domain(PS) state = Attached
Registration state(EMM) = Registered
EMM Sub State = Normal Service
Tracking Area Code (TAC) = 15021
Cell ID = 35896601
Primary Scrambling Code = 65535
cisco2911#show cellular 0/0/0 profile
Profile 1 = INACTIVE* **
PDP Type = IPv4v6
Access Point Name (APN) =
Authentication = None
Profile 10 = INACTIVE
PDP Type = IPv4v6
Access Point Name (APN) = internet.eplus.de
Authentication = PAP or CHAP
Username: xxx
Password: yyy
here is the actual config. Unfortunately we dont have internet via Ethernet for testing the network so just LTE would be availeble for testing the entire network.
Current configuration : 6366 bytes
! Last configuration change at 12:19:32 UTC Tue May 8 2018 by admin
version 15.4
hostname cisco2911
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool k130
import all
dns-server 8.8.4.4
ip cef
no ipv6 cef
cts logging verbose
redundancy
lte sim data-profile 10
no ip address
shutdown
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
ip address dhcp
duplex auto
speed auto
ip address negotiated
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 10
async mode interactive
ip http server
ip nat inside source list 10 interface Cellular0/0/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0 dhcp
dialer-list 10 protocol ip permit
access-list 10 permit 10.0.130.0 0.0.0.255
control-plane
Hello Ralf,
you are missing a few things for the cellular to work. I amended your config (cell parts marked in bold):
version 15.4
hostname cisco2911
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool k130
import all
dns-server 8.8.4.4
ip cef
no ipv6 cef
cts logging verbose
redundancy
no ip address
shutdown
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
ip address dhcp
duplex auto
speed auto
ip nat outside
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string lte
dialer-group 1
ip http server
ip nat inside source list 1 interface Cellular0/0/0 overload
line 3
exec-timeout 0 0
password cisco
script dialer lte
login
modem InOut
no exec
transport input all
thanks a lot for the quick reply. I will try this config asap. What is the meaning of this:
the chat script is used for communication between the router and the modem. It basically tells the modem  to call, and wait for 60 seconds...
That said, chat scripts may differ depending on your provider. Who is your ISP ? (e.g. O2, T-Online, TS2 Space)...
