cisco 2911 no internet behind router
Ralf110666
Hello, good morning.
i have problems to get access to the internet behind an 2911. Config should be as follows.
internet is provided by an external dhcp server. signal comes through ge 0/1/0. The 2911 should be standard gateway and dhcp server for the connected clients on ge 0/0 (will be a switch later). ge 0/2/0 should be backup for ge 0/1/0 and cellular 0/0/0 should be backup for ge 0/2/0. But at the moment i am not able to get internett on a connected client at ge0/0.
I figured out the following:
2911 dhcp server is giving ip addresses through ge 0/0 as it should be ( nw 10.0.130.0 excluded 10.0.130.1-30) so i get the first ip 10.0.130.31 at a connected client.
2911 gets an ip from external dhcp on ge 0/0/0
ping is working via console on the 2911 (8.8.8.8)
ping is also translating adresses via console (www.google.com, www.cicso.com)
on a connected client at ge 0/0 i can ping the cisco2911 (static ip 10.0.130.254)
but i can not ping anything from the internet. Network connection shows no internet at windows10
actual config:
! Last configuration change at 16:06:00 UTC Sun Apr 29 2018 by admin
version 15.4
hostname cisco2911
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
--More--  !
no ip dhcp conflict logging
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.0.130.1 10.0.130.30
ip dhcp pool k130
import all
network 10.0.130.0 255.255.255.0
dns-server 8.8.4.4
default-router 10.0.130.254
ip domain name LUDWIGSHAFEN
ip name-server 10.0.130.254
ip cef
no ipv6 cef
--More--  multilink bundle-name authenticated
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
cts logging verbose
redundancy
controller Cellular 0/0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
--More--  !
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.0.130.254 255.0.0.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
--More--   no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1/0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/2/0
backup interface GigabitEthernet0/1/0
ip address dhcp
duplex auto
speed auto
interface Cellular0/0/0
no ip address
encapsulation slip
dialer in-band
dialer string lte
--More--  !
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat source list 1 interface GigabitEthernet0/1/0 overload
ip route 0.0.0.0 0.0.0.0 dhcp
access-list 1 permit 10.0.130.0 0.0.0.255
control-plane
31 Replies 31
the provider is e plus  and i thought i got to input the apn , user name and pw somewhere.
Thank you so much Georg.
100% success i am now attached to an 3650 switch behind the router and its working fine.
best regards
Ralf
