Cisco 2911 router WAN setup. help !!!
thedippower
I am very new to CISCO. Our office bought a CISCO 2911 Router. Fact is: from ISP to connect with WAN we got real Ip of : xxx.xxx.xxx.10 / 29 and their gateway is xxx.xxx.xxx.9 . In the office I need to setup LAN with IP block 192.168.1.1 Subnet Mask : 255.255.0. 0 . We need to use static ip inside the LAN. I need to configure the router so that all can access internet. Can someone help me with it by showing the configuration script.
lmediavilla
There is more data needed, do you authenticate to the PE or any speciall encapsulation?
PPPoE, 802.1Q, any requierement from your ISP?
kind regards
Angus Bishop
What kind of ISP setup you have .
What switch you have ( L3 / L2 )
Please explain in detail ..
Agnus
