Cisco 2911 with multiple Internet connections
andy_4578
I'm sure this question comes up alot but i cant find a deffinative answer.
We are about to install a cisco 2911 router to replace a linux based router.
The Cisco will have 5 gig ports, 4 ports connected to DSL modems each modem connected to a different ISP, and the last port connected to a Cisco LAN switch.
802.1q will be used on the internal router port to split the LAN segments up into VLAN's as the building contains lots of different businesses.
Each customer in the building has there own servers and set of public IP addresses assigned e.g
Customer A - ISP 1      uses  81.34.65.78 NAT'd to 10.0.0.1 Vlan 5 port 25 (SMTP)
Customer B - ISP 2     uses 217.23.67.87 NAT'd to 192.168.1.1 Vlan 6 port 25 (SMTP)
and so on
The outbound traffic also needs to go out of the correct DSL line which ever has been assigned to that customer.
Am i right in thinking the only way to do this will be to use "Route Maps" ??
(IP addresses above are made up, or at least not ours)
3 Accepted Solutions
Please correct me if I'm wrong guys, but I believe you would add the route-map to your subinterfaces, since you're doing Routing on a stick.
access-list 115 permit ip 10.0.0.0 0.0.0.255 any
access-list 116 permit ip 192.168.1.0 0.0.0.255 any
route-map VLAN5-OUT permit 10
permit ip access-list 115
set ip next-hop 81.34.65.78
route-map VLAN6-out permit 20
permit ip access-list 116
set ip next-hop 217.23.67.87
int x/x.5
ip address 10.0.0.1 255.255.255.0
ip policy route-map VLAN5-OUT
int x/x.6
ip policy route-map VLAN6-OUT
And, you can leave your default route there if you want.
yes, under route map its match ip add 115,
when there are packet that match the access-list 115, then this packets will go to the address that you configure in set ip next-hop
if it doesnt match, it will check the other route map, of no other route map being matched, it will use the normal routing process.
regards,
permit ip access-list 115 is not accepted because permit is not a valid action in that part of the route map. In that part of the route map you can use match or you can use set, but permit is not a valid option. match ip address 115 is what you want to use and it will use access list 115 to identify the traffic to be policy routed.
And yes the IP address specified is the next hop address and not the outside interface address.
Rick
Rick
19 Replies 19
JohnTylerPearce
Level 7
Level 7
I would configure PBR for this.
For example:
On the subinterface on the GigE port on the 2911 going to all LANs, for that specific vlan 10.0.0.1 I would create
a route map, and have a next-hop for the specific ISP.
PBR is certainly one possibility (and I believe that this is what the original poster was meaning when he talked about using route maps). I would think that another possibility would be to configure VRFs with a VLAN and an outside interface in a VRF for each of the customers.
Rick
Rick
i would agree to all of you in using PBR. its much simpler.
@Richard,
have you implement vrf with vlan for these kind of situation? whats the advantage?
regards,
andy_4578
Could any one give me an example of how a PBR/Route Map would look assuming...
Vlan 5 - Subnet 10.0.0.0/24 needs to send all traffic out of External IP - 81.34.65.78
Vlan 6 - Subnet 192.168.1.0/24 needs to send all traffic out of External IP - 217.23.67.87
Am i right in thinking the route maps will apply before the default route..
ip route 0.0.0.0 0.0.0.0 87.34.43.2 gi0/0
Takes effect.
int x/x.5
int x/x.6
http://www.cisco.com/en/US/products/ps6599/products_white_paper09186a00800a4409.shtml#wp14019
http://www.ciscopress.com/articles/article.asp?p=102092
yes you are right, route map will be done before any routing decisions.
i think you want to use the set ip default network
after configuring this, you can check the traffic path by using traceroute from the user in vlan 5 and 6
regards,
andy_4578
Thanks for the quick response John, i'm installing the router tomorrow morning i'll try it then and mark answers correct where applicable, looks good to me though
No problem Andy, I ask for help as well sometimes. I figured if I ask for help, I might as well answer some questions too
andy_4578
Finally getting round to trying this but get stuck when i try and enter..
The part in bold is not accepted, any ideas?
What part is being set in bold?
Curtis
andy_4578
The "permit ip access-list 115" is not an accepted command when i try and created the route-map.
I've used "match ip address 115" instead im guessing its the same thing.
The set ip next-hop x.x.x.x am i right in thinking that will be the IP address of the next router and not the outside interface address?
regards,
Rick
Rick
andy_4578
Thanks for all your help guys it's working perfectly, the old linux box can go in the bin!!
