Cisco 2921 - can not access Web server
maciumpek91
Dear friends
I need help With my cisco router. I have CISCO2921-SEC/K9 with  EHWIC-4ESG.
What I want I access to web server from my internal network and from whole internet.
My public IP on WAN port is 212.87.232.8. My internal network which is 192.168.1.0/24 and the web server ip is 192.168.1.10. I am doing NAT on 212.87.232.8. Typically I should enable port 80 for server's ip and it should work - on any other router it works but on that cisco - doesn't
I have checked a lot forums and tried different solutions but it wont work. May You can help ?
Please check my config - probably I am missing something:
version 15.4
hostname RouterAP
boot-start-marker
boot-end-marker
no aaa new-model
! ip dhcp pool PULA1
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 8.8.8.8
interface GigabitEthernet0/2
 description ##WAN2##
 ip address 212.87.232.8 255.255.255.240
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/0/0
 no ip address
interface GigabitEthernet0/0/1
 no ip address
interface GigabitEthernet0/0/2
 no ip address
interface GigabitEthernet0/0/3
 no ip address
interface Vlan1
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool PULA8 212.87.232.8 212.87.232.8 netmask 255.255.255.240
ip nat inside source list 108 pool PULA8 overload
ip nat inside source static tcp 192.168.1.10 80 interface GigabitEthernet0/2 80
ip nat inside source static tcp 192.168.1.10 80 212.87.232.8 80 extendable
ip route 0.0.0.0 0.0.0.0 212.87.232.1
access-list 108 permit ip 192.168.1.0 0.0.0.255 any
access-list 108 permit tcp any host 192.168.1.10 eq www
11 Replies 11
Julio E. Moisa
Do you have Internet access on the internal web server?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes, I have
Thank you, have you tried Natting with other IP of the public pool, for example  .7?
Yes - the same problem
I tried to reach the IP 212.87.232.8 from my browser and it opened a website
That is right - because now it is not working on cisco router but on other.
But do You think I am missing something in my config ?
maciumpek91
Anybody has any idea ?
Thanks in advance
try and take the line below out of your static NAT config:
--> ip nat inside source static tcp 192.168.1.10 80 interface GigabitEthernet0/2 80
so you are just left with:
For the sake of completeness, also add:
ip dhcp excluded-address 192.168.1.1
Thank You.
I did this: ip nat inside source static tcp 192.168.1.10 80 interface GigabitEthernet0/2 80
And the same problem. No access
You could try executing a debug ip nat and try again it could be receiving the request.
Alan Ng'ethe
Level 3
Level 3
Why do you need a pool for this?
I would just overload using the public IP of the router like this:
ip nat inside source list 108 interface GigabitEthernet0/2 overload
Then, i would modify this line to see whether it is generating any hits.
access-list 108 permit tcp any host 192.168.1.10 eq www log
I would be tempted to delete the last line of access list 108 as I am not completely sure its necessary.
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
