cisco 2921 error
Ronen Benjamin
i am trying to write a event manger applet :
 action 0010 regexp "^.([0-9][0-9][0-9]):.:.DROP. ([0-9.]+).* -> .*" "$_syslog_msg" _knock_RegEx_Match _knock_Sequence_E1 _knock_Source_E1
 action 0020 info type event reqinfo tag _knock_Tag_E2
 action 0030 regexp "^.([0-9][0-9][0-9]):.:.DROP. ([0-9.]+).* -> .*" "$_syslog_msg" _knock_RegEx_Match _knock_Sequence_E2 _knock_Source_E2
 action 0100 if $_knock_Sequence_E1 lt $_knock_Sequence_E2
my router does not recognize the '$' of the variable , why ?
Cristian Matei
    You mean the parser gives an error message when you put the command in? Can you post the exact error you get?
Cristian Matei.
when i configured  : action 0010 regexp "^.([0-9][0-9][0-9]):.:.DROP. ([0-9.]+).* -> .*" "$_syslog_msg" _knock_RegEx_Match _knock_Sequence_E1 _knock_Source_E1
the show run command gives me the output:
 action 0010 regexp "^.*([0-9][0-9][0-9]):.*:.*DROP.* ([0-9.]+).* -> .*" "_knock_RegEx_Match" _knock_Sequence_E1 _knock_Source_E1
with missing  "$_syslog_msg" as i configured in the command line
and when i configured : action 0100 if $_knock_Sequence_E1 lt $_knock_Sequence_E2  , i got an error  :
see the attached file
 I’m far from being good with TCL, so either the syntax is wrong, either you hit a bug and should upgrade.
Cristian Matei.
