Cisco 2921 ISR2 IOS 15.0 router GRE over IPsec configuration problem
josephp
Hi Folks,
I need a little help with configuration of a 2921 ISR2 router. I am trying to configure GRE over IPsec as a backup link (primary link is on a metro-ethernet) with OSPF. However I don't see an option to enable crypto isakmp policy #. I don't see an option to enable it, below is the show version and help options availble for crypto. Am I missing a step? or do I have the wrong IOS version?
rtr01#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 02-Dec-09 15:23 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M1, RELEASE SOFTWARE (fc1)
rtr01 uptime is 2 weeks, 6 days, 7 hours, 52 minutes
System returned to ROM by reload at 15:30:50 UTC Wed Sep 1 2010
System image file is "flash0:c2900-universalk9-mz.SPA.150-1.M1.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID <snip>
3 FastEthernet interfaces
3 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          <snip>
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      None          None          None
uc            None          None          None
data          None          None          None
rtr01#
rtr01#
rtr01#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
vpnrtr01.nj3-1.sup(config)#crypto ?
  ca   Certification authority
  key  Long term key operations
  pki  Public Key components
rtr01(config)#crypto isakmp policy 10
% Invalid input detected at '^' marker.
rtr01(config)#
Thank you in advanced.
Joe P.
Leo Laohoo
It's because your IOS feature is "IP Base".  I believe GRE support require IP Services.
