Cisco 2921 Router- Help with Routing for multiple gig interfaces
dstriplin1
Hi All,
I'm trying to relocate my lab rack to my basement, but want to keep one switch in my office.  I've got a 2921 router, a 3750 switch, and a basic managed netgear switch.  Everything is working fine, but I'm trying to duplicate the settings out of my router so both gig0/1 and gig0/2 do the exact same things.  Is that possible?
Right now, gig 0/1 plugs into my cisco switch on 10.0.1.0/24 and it pipes the feed from my router upstairs to my office.  I'd like to enable gig0/2 to have the exact same ip addressing and route config as gig0/1 so that I can feed a small netgear switch in the basement, is that possible using the same 10.0.1.0/24 address scheme?  Here is my 2921 show run
Lab_2921#show run
Building configuration...
Current configuration : 2091 bytes
! Last configuration change at 12:35:23 EST Sat Apr 6 2019 by davidstriplin
version 15.7
hostname Lab_2921
boot-start-marker
boot-end-marker
enable secret 5 $1$SsVR$V9SJLHz03PmbBnBTIG5t51
no aaa new-model
clock timezone EST -5 0
ip dhcp excluded-address 10.0.1.170
ip dhcp excluded-address 10.0.1.100 10.0.1.254
ip dhcp pool Inside DHCP
network 10.0.1.0 255.255.255.0
dns-server 75.75.75.75 75.75.76.76
default-router 10.0.1.1
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
license udi pid CISCO2921/K9 sn FTX1728AHR1
username davidstriplin secret 5 $1$zXDh$kKFRLQfASKutBCb7iYOMI1
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Facing The ISP (WAN)
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description Facing The LAN (LAN)
ip address 10.0.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/2
description Secondary Feed to Basement
no ip address
ip nat inside
shutdown
duplex auto
speed auto
ip default-gateway 10.0.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
ip ssh time-out 60
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 any
control-plane
vstack
line con 0
logout-warning 120
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password AlphaBravo9
login local
transport input ssh
scheduler allocate 20000 1000
end
you can only assign the same IP address to two interfaces on your 2921 when one of the interfaces is shut. If both are active, you will get an error message...
It is not entirely clear, to me, what you want to accomplish...do you want traffic coming from the switch to be NATted out to the Internet ?
