Cisco 2941 Router Issue
lalit
Hi Team,
I need a help on Cisco MWR 2941 Router ( Mobile Wireless Edge Router ).
I have a Cisco MWR 2941-DC-A Router running IOS " mwr2941-adviprank9-mz.150-1.MR.bin " .I am not able to configure ip address on the interface.When I am trying to configure no switchport on the interface it gives me an error as " Not a convertible port "
Can we configure one of the port on Cisco MWR 2941 Router as routable port.Is the present IOS supports to configure ip address on the interface ?
Please let me know.
Thanks & Regds,
Lalit
vmiller
Level 7
Level 7
I believe the 2 gig interfaces are just garden variety interfaces. skip the no switch port stuff
according to what I have seen, they should take an IP address.
If not, might want to contact the TAC
Jon Berres
Level 4
Level 4
As far as I know you cannot assign IP Addresses to the physical interfaces on the MWR2941. You need to assign VLANs and then create a VLAN INT if you need an IP on the MWR. This does create more work if you want to route between mutliple interfaces.
vmiller
Level 7
Level 7
which interface?
capture your terminal session when you try to configure and post it here
In Cisco MWR 2941, we know that the maximum configuration is 16E1 + 6GE and 9 FE. I want to know what will be the maximum capacity of the BOX ?. I think the backplane capacity of the Box is only 6GE, so can it support full configuration as above?
