sham-link question
yuchenglai
Hi All,
I have a question regarding sham-links. If I use a sham-link between two PE  routers, I know that a /32 address on the OSPF VRFs of the PEs must be  advertised via MP-BGP.
However,  if the VRFs running OSPF on the two PE routers want to learn about one another's OSPF  routes via the Sham-Link, can I assume that there is no need to  redistribute the OSPF into MP-BGP on the two PE routers?
David
Marwan ALshawi
you still need the redistribution for routing/forwarding over the core
the shame-link is spcial tunnel like virtual-link connect to PEs in same area and is used to establish
OSPF adjacency and LSA exchange
the LSA loaded to the OSPF Database and the intra-area route used over the sham-link for computing the path
HOWEVER, when the route being installed in a VRF's RIB the forwarding will be based on the MP-BGP learned routes based on prefix-match
the relevant VPN and lable then used for the packet forwarding over the MPLS core
so the info loaded across the Sham-link used for OSPF SPF calculations and best path selection
while the forwarding done via the info learned through MP-BGP
if helpful Rate
That was very helpful, thanks.
I think you summed it up for me with your last statement:
"so the info loaded across the Sham-link used for OSPF SPF calculations and best path selection
while the forwarding done via the info learned through MP-BGP"
Marwan ALshawi
Happy to help
