06-17-2022 04:23 PM
I've a project, our customer is going to replace his old MPLS running Customer Edge routers to newer version, 2951 to 4431.
i was wondering if this is possible I can take configuration backup from 2951 and restore it to directly on 4431?? I doubt this will not possible cause 4000 routers are running on IOS XE.
Solved! Go to Solution.
06-21-2022
03:42 PM
- last edited on
07-06-2022
12:34 PM
by
Translator
Thank you Mr. Burts,
for staying along the journey, I landed in evening here and directly go to site, as we planned to do it in off working hrs. I followed the step and restore the configurations of 2951 by editing interface names accordingly. One surprise was there, when issued
reload
command, it got stuck on boot, after few tries it booted. Configurations was success, we connected it to production network, customer tested SAP access to HO back and other apps. Everything seems good so far. Only thing I'm afraid of is boot, though i set the command but still I'm afraid to issue
reload
command. pasting below.
I'm unable to delete following entry in bootstrap in isr 4431
boot-start-marker boot system flash:c2900-universalk9-mz.SPA.150-1.M2.bin
Though I added
isr image fron boot system
command, now showing two entries, in boot system flash:
Any help with this one??
06-21-2022
07:01 PM
- last edited on
07-06-2022
12:35 PM
by
Translator
What is the result if you try this
boot-start-marker
no boot system flash:c2900-universalk9-mz.SPA.150-1.M2.bin
06-22-2022 09:09 AM
The Result as I mentioned before, is horrible, ISR 4431 stuck on boot for around 15 mins, then it booted to default image. That's a problem.
06-22-2022
03:04 PM
- last edited on
07-06-2022
12:36 PM
by
Translator
Hi Mr. Burts,
here's the output i could get.
CER1#show run | inc boot boot-start-marker boot system flash:c2900-universalk9-mz.SPA.150-1.M2.bin boot system flash:isr4400-universalk9.16.03.05.SPA.bin boot-end-marker no ip bootp server ip dhcp bootp ignore diagnostic bootup level minimal
I can't delete entry
Please advise, I tried
command, it executed but this entry still there.
06-22-2022
03:21 PM
- last edited on
07-06-2022
12:40 PM
by
Translator
I am sorry to hear that there have been issues in the transition. I am slightly puzzled that the boot process took 15 minutes. Did you by any chance get a copy of the console output during the boot process?
I am not sure that I understand this statement "then it booted to default image." Can you provide clarification?
If you do a
show version
on the new router, is it running the version of code in your
boot system command (isr4400-universalk9.16.03.05.SPA)?
07-05-2022
07:16 PM
- last edited on
07-06-2022
12:43 PM
by
Translator
Hi Richard,
Sorry for the delayed response, You're right default image I meant was isr4400.bin image.
and after couple of tries, I was able to remove c2900 image from boot system also.
Now we've another phase, where c2800 Router is there, Same we've to do and I'm confident i'll do configuration restore here too. Still pasting down the
show run
if you've any suggestions please add. we've just reached the city, checked into hotel, probably will visit the site after taking basic 6 hrs of sleep.
here's show version,
EdgeRouter1#shw ow runn EdgeRouter1#show running-config Building configuration... Current configuration : 2569 bytes ! version 12.4 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname EdgeRouter1 ! boot-start-marker boot-end-marker ! logging message-counter syslog no logging buffered enable secret 5 $1$Lxb.$ztT/JAXcb7IwnZPYkJ0cH. ! no aaa new-model ! dot11 syslog no ip source-route ! ! ip cef ip dhcp bootp ignore ! ! no ip bootp server no ip domain lookup ip domain name mc2hail.local ! multilink bundle-name authenticated ! ! ! ! ! ! username admin privilege 15 secret 5 $1$lnz4$/MLoasEzgo79ztz55zbqG. username mc2admin privilege 15 secret 5 $1$B9gR$SXj3mhMjqRwWdsAlL7fD8. username user-name secret 5 $1$gyTl$aezJ3ZLCdMPFgo3esTy2N. archive log config hidekeys ! ! ! ! ! ip ssh version 2 ! ! ! interface Loopback0 ip address 192.168.163.1 255.255.255.252 ! interface FastEthernet0/0 description Connection to MC2 IP VPN Cloud no ip address no ip unreachables no ip proxy-arp duplex auto speed auto no cdp enable no mop enabled ! interface FastEthernet0/0.3161 encapsulation dot1Q 3161 ip address 10.10.4.34 255.255.255.252 ! interface FastEthernet0/1 description connected to MC2 private Hail ip address 192.168.160.1 255.255.254.0 no ip unreachables no ip proxy-arp duplex auto speed auto no cdp enable no mop enabled ! router ospf 1 log-adjacency-changes network 192.168.96.40 0.0.0.3 area 0 network 192.168.160.0 0.0.1.255 area 0 ! router bgp 65272 no synchronization bgp log-neighbor-changes redistribute connected neighbor 10.10.4.33 remote-as 65000 no auto-summary ! no ip forward-protocol nd ip route 192.185.41.249 255.255.255.255 192.168.160.7 no ip http server ip http authentication local no ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 ! ! ! snmp-server community mc2hailbw RO no cdp run ! ! ! ! ! control-plane ! banner motd ^C This Device Belongs to Second Milling Company (MC2) UNAUTHORIZED ACCESS TO THIS DEVICE IS PROHIBITED STOP IMMEDIATELY You must have explicit, authorized permission to access or configur this device, Unauthorized attempts and actions to access or use this device may result in civil and/or criminal penalties. All activities performed on this device are logged and monitored Contact IT Security Officer (270).^C ! line con 0 password 7 030A5206020E701D login line aux 0 login local no exec line vty 0 4 login local transport input ssh line vty 5 15 login local transport input ssh ! no scheduler allocate end
07-05-2022
08:45 PM
- last edited on
07-06-2022
12:45 PM
by
Translator
Thanks for the update. Glad to know that you resolved the issue on the router.
The config of this router is fairly simple and I have these comments/suggestions:
- this router specifies "ip ssh version 2" It is not clear whether the first router was using SSH. This router clearly is using SSH and specifies version 2, which is more secure. Before you can execute the
ssh version
command you need to enable SSH.
- under router ospf there is a reference to
But that network is not configured on any interface. There were also references to this network on the first router. So whatever you did about this on the first router may well work here also.
There will be some syntax differences as you transition to the new router. But transferring the config should be fairly straightforward.
06-21-2022 03:44 PM
For BGP output,
I'll share here the output once i collected tomorrow. We're in different time zones, so you might see it next day.
