BGP default-information originate
jpl861
Level 4
Level 4
Hi BGP experts,
How does
default-information originate advertise default route
? We have lots ISPs and we are only asking those ISPs to advertise
default routes
to our network. We are connected to ISPs using eBGP.
One of our ISP router advertise 0.0.0.0 network to our internal network via iBGP by using
command. Actually, not only one
 ISP router
was configured this way. All of them except one.
However, we have one
ISP router, also in a different site that advertises 0.0.0.0 to its iBGP peers without the
command. How did this happen?
Take note that 0.0.0.0 is always being advertised by the ISP. We don't have
static routes
to 0.0.0.0 configured in any of our routers.
What if I remove the
to all of the
ISP routers
? What will happen? Since one of our
ISP router
Need clarification. Thanks Guys.
-John
Hi John,
I am glade that you are building it up right, but please note that BGP never advertise a
default route (iBGP or eBGP)
unless one of the 3 actions explained above is taken.
HTH,
Mohammed Mahmoud.
12 Replies 12
royalblues
Level 10
Level 10
John,
The default-information originate
command is used to configure a
BGP routing, process to advertise a
default route (network 0.0.0.0).
A
redistribution
statement must also be configured to complete this configuration or the
default route
will not be advertised.
The configuration of the
command in BGP is similar to the configuration of the
 network (BGP)
command.
The default-information originate command
, however, requires explicit
 redistribution of the route 0.0.0.0
. The
network
command requires only that the route 0.0.0.0 is present in the Interior Gateway Protocol (IGP) routing table. For this reason, the
network
command is preferred.
if u remove the ,
command, the routers which were receiving this
prefix via this router
would purge this entry and can cause an outage as well
HTH, rate if it does
Narayan
mohammedmahmoud
Level 11
Level 11
Hi John,
A default route
can be originated from a BGP neighbor in 3 ways:
1. default-information originate + redistribute static (or any dynamic routing protocol having the default route - you may filter only the default route)
2. network
command but must make sure the
default route
is present in the routing table
3. Another way of advertising a
default route
to a specific BGP neighbor is by issuing the
neighbor default-originate
command. This method does not require the presence of the 0.0.0.0/0 network in the routing table of the advertising router.
command in BGP is similar to the configuration of the ,
network (BGP)
command.
command, however, requires explicit
redistribution of the route 0.0.0.0.
The
network
network
Check which method did this ISP router use in order to take the right decision, before removing or changing anything.
HTH, Please rate if it does,
Mohammed Mahmoud.
Thanks for the reply guys. We don't have any
redistribution
in any of our
ISP routers
. I just want to ask what is the difference between the two? Here's a config of one of our edge routers.
router bgp 2456
no synchronization
bgp log-neighbor-changes
network 203.167.7.0
timers bgp 15 45
neighbor 10.199.2.2 remote-as 2456
neighbor 10.199.2.2 update-source FastEthernet0/0
neighbor 10.199.2.2 next-hop-self
neighbor 10.199.2.3 remote-as 2456
neighbor 10.199.2.3 update-source FastEthernet0/0
neighbor 10.199.2.3 next-hop-self
neighbor 10.199.2.112 remote-as 2456
neighbor 10.199.2.112 update-source FastEthernet0/0
neighbor 10.199.2.112 next-hop-self
neighbor 10.199.2.113 remote-as 2456
neighbor 10.199.2.113 update-source FastEthernet0/0
neighbor 10.199.2.113 next-hop-self
neighbor 203.167.2.242 remote-as 968
neighbor 203.167.2.242 ebgp-multihop 255
neighbor 203.167.2.242 update-source FastEthernet0/1
neighbor 203.167.2.242 version 4
no auto-summary
This configuration advertises
default-route
to 10.199.2.2 and 10.199.2.3. These are internal routers.
Here's another configuration.
router bgp 2456
no synchronization
network 121.97.1.0 mask 255.255.255.0
neighbor 10.19.0.2 remote-as 2456
neighbor 10.19.0.2 update-source GigabitEthernet0/0
neighbor 10.19.0.2 next-hop-self
neighbor 10.19.0.3 remote-as 2456
neighbor 10.19.0.3 update-source GigabitEthernet0/0
neighbor 10.19.0.3 next-hop-self
neighbor 121.97.7.93 remote-as 6648
neighbor 121.97.7.93 soft-reconfiguration inbound
This also advertises
 default-route
to 10.19.0.2 and 10.19.0.3 which are internal routers. But this was configured without the
command. What's the difference between the two? We only accept
default-routes
from the ISP. Thanks Guys.
Hi John,
The
command in BGP doesn't work without
redistribution
(search for it under the address-family ipv4 under the BGP process), or else search for the
network 0.0.0.0
or finally Check for this command under bgp process under the
address-family ipv4:
address-family ipv4
neighbor x.x.x.x default-originate
HTH, please rate if it does help
Mohammed Mahmoud.
So the second configuration is really enough to advertise
default routes
to iBGP peers since I'm receiving
default routes
from the ISP?
So what you mean is that, the purpose of
command is to advertise
default-route if the default-route
was received from IGP like OSPF/EIGRP or if it was statically configued?
But if the the
default-route
was received from an eBGP peer then the edge router will automatically advertise this to internal network?
Hi John,
HTH,
Mohammed Mahmoud.
So BGP will not advertise
default-route to iBGP or eBGP
peer if I don't have a route to 0.0.0.0? For example, my edge router is not running eBGP with the ISP. I can't make my edge router advertise 0.0.0.0 to iBGP peers if I don't use a
static route
pointing to ISP then
redistribute
it to BGP? Then I need to issue
command to advertise 0.0.0.0 to iBGP peers.
Because I was thinking of the
being used by OSPF. Correct me if I'm wrong, in OSPF, if I use
always then I'll be able to advertise a
default route
to the network even if I don't have a route to 0.0.0.0?
the only purpose of the
command in BGP is to allow the
redistribution of the default route in BGP,
. It doesn't generate the
default route
as it is the case for OSPF.
The
command on the other hand, does advertise the
default route, to the specific neighbor whether it is present in BGP or not.
Hope this helps,
Hi John,
In the case of BGP, if you are using the
default-information originate the default route
must be in the routing table, but if using the
in front of a
neighbor the default route
doesn't need to be in the routing table.
While OSPF has the always keyword, BGP doesn't.
HTH,
Mohammed Mahmoud.
Now I get it. :) Thanks for all the help guys.
John
You're welcome hehe, brother :)
Hi Mohammed,
With respect to the way 2 -
network
command.
I understand that besides having the 0.0.0.0/0 route is present in the Interior Gateway Protocol (IGP) routing table, rather having it
(the default route)
defined as a valid/functional
static route
at the router should meet the criteria for such method.
The scenario being:
default static route configured on the router + the network command
under the ipv4 address family within the
 BGP
configuration, should do the trick to inject it to the BGP neighbor(s)
Correct?
Thank you
